  • June 25, 2025, 08:41:58 PM
Author Topic: CL model carrier  (Read 1597 times)
Offline t michael jennings
  • AMA 83322
CL model carrier
« on: March 16, 2007, 03:47:30 PM »
Has anyone designed or build a good CL model carrier for a van?
I am looking for a carrier that will hold 2 or 3 models.
t michael jennings
Offline Richard Grogan
Re: CL model carrier
« Reply #1 on: March 16, 2007, 04:19:20 PM »
Is it a van full of seats, or an empty /cargo type van? Mini van or full sized?
Long Live the CL Crowd!
                  AMA 85745
Offline Clancy Arnold
« Reply #2 on: March 16, 2007, 08:43:56 PM »
Check with Allen Brickhaus.  I saw the method he uses and it looked great.  Used a sheet of 2 inch thick blue insulation foam with notches and the models are held on edge.  Holds several planes.
Clancy
Clancy Arnold
U/Tronics Control
Offline Warren Wagner
  • Bradenton, FL
« Reply #3 on: March 17, 2007, 09:15:29 AM »
t michael jennings
Michael,
Here is a plane carrier that has worked out superbly for me.   It's not my design....I originally saw it in a column by Bob Hunt.
I used a piece of the dense "pink foam"  (don't know the proper term for it ) that you can find at any home improvement store.    If you look closely, you can see that the height had to be increase about 6".  The seam would look better on the bottom.  You will have to experiment with the heigth of the carrier, and the depth of the slots, which are both dependant on the size of your planes.   There is a pair of "feet" made from 1" x 3" pine to stabilize the carrier.
In order to maintain the good appearance of my very expensive van, I took a color sample to the paint store, and had a quart of paint mixed that matches the interior of the van.
This carrier has the capacity of carrying 6 planes, but you can adjust the distance between slots to accommodate your needs.
It is well worth the time that it takes to fabricated the carrier....hanger rash will go to zero.
Cheers.
Warren Wagner
Warren Wagner
AMA 1385
Offline newell follett
« Reply #4 on: March 17, 2007, 09:44:18 AM »
Warren
What are the two planes on the right??
The yellow and the unfinished one.
Regards Newell
  • Bradenton, FL
« Reply #5 on: March 17, 2007, 12:56:42 PM »
Warren
Regards Newell
Newell,
The yellow plane is a "Viking" (check the tail graphics) which was built by Owen Richards (Ellenton, FL), and I flew it in Old Time for a while, and eventually sold it.   The plane in "bones" is the Southwick "Skylark".
Cheers.
Warren Wagner
Warren Wagner
AMA 1385
Offline Ward Van Duzer
« Reply #6 on: March 21, 2007, 08:38:03 AM »
This type of holder/carrier works well for non-piped ships. But I prefer to carry my piped stuff flat, on the landing gear. That way the oils, etc. from the pipe don't flood back into the engine. Just my thought. With enough egg crate soft foam you can "sandwich" a couple of ships...
W.
