  • July 19, 2025, 08:58:33 PM
Author Topic: Best way to remove monicote from bare balsa  (Read 1239 times)
Offline David Fretz
« on: July 21, 2018, 08:17:25 AM »
The monicote only comes off in small strips. How do I remove?
Online Gerald Arana
Re: Best way to remove monicote from bare balsa
« Reply #1 on: July 21, 2018, 08:54:48 AM »
Remove the remaining glue with acetone on a paper towel. Wipe, repeat!
Good luck, Jerry
PS: I have better luck with a #10 exacto. Less nicks.
Online Gerald Arana
« Reply #2 on: July 21, 2018, 09:08:39 AM »
Ty,
YES! Thank God for #*&^-up putty!  LL~ LL~ LL~ LL~ LL~
Jerry
Offline David Fretz
« Reply #3 on: July 21, 2018, 10:42:56 AM »
Thanks, guys
« Reply #4 on: July 21, 2018, 01:05:14 PM »
David,
These wings, ARF R/C Spitfire, weren't covered with a quality iron on like Monokote, so I would guess Monokote would be easier to remove? A guess.
First time I removed an ARF covering and as it was said, I used a #11 blade also and just took my time.
Plenty of really tiny pieces but eventually they were all gone.
I cleaned the wing up with Acetone also. It does the job.
Not too shabby when done and, in my case, well worth the effort.
Good luck.
Offline Carl Cisneros
« Reply #5 on: July 21, 2018, 06:25:14 PM »
was that a World Models Spitfire?
Carl R Cisneros, Dist IV
Control Line RB
« Reply #6 on: July 21, 2018, 06:50:41 PM »
Carl,
Phoenix Models I believe.
Charles
Offline Larry Renger
« Reply #7 on: July 21, 2018, 09:10:39 PM »
I got a clue somewhere in this forum some years ago, and it WORKED! #^
I set my razor plane for a minimum cut and just carved the 'Kote off. Naturally, with a bizzare technique like this it was tried on a not an especially valuable plane. But it came out fine! Probably less balsa lost than a final sanding!
Good luck!  H^^
