  • July 18, 2025, 04:21:17 AM
Author Topic: Bending music wire  (Read 1284 times)
Offline Russell Shaffer
Bending music wire
« on: October 01, 2006, 07:11:23 PM »
I have been heating music wire to get a sharp bend, then letting it cool.  Is this good, or should I quench it to re-harden?  Or is heating a bad thing?
Russell Shaffer
Klamath Falls, Oregon
Offline RC Storick
Re: Bending music wire
« Reply #1 on: October 01, 2006, 07:13:20 PM »
Bend it cold
Offline Richard Grogan
« Reply #2 on: October 01, 2006, 08:37:41 PM »
Hammer* + Vise = Bend !!      (*Requires muscle!) **)
Long Live the CL Crowd!
                  AMA 85745
Offline Crist Rigotti
« Reply #3 on: October 01, 2006, 09:03:03 PM »
Be sure you have a radius on the bend or you'll put in a stress point.  Radius the vise jaws some or use what I do the K&S bending jig.  The small one.  I'll bend 1/8 music wire with it.
Offline Tom Perry
« Reply #4 on: October 02, 2006, 07:09:23 AM »
Russell,
If you absolutely must heat the wire to bend it, it will be to soft to function properly.  To fix this you should heat it then plunge it in cold water.  This will leave it too hard and subject to breaking.  You can try to re-temper it by heating it in an oven to about 450 degrees and then letting it cool slowly.  This will bring back some of the temper or toughness.  Sparky gave the best advice "bend it cold".  The tempering heat is based on the carbon content of the steel so the 450 degrees is just a ball park guess.
Tight lines,
Tom Perry
 Norfolk, Virginia
