  • June 21, 2025, 03:33:05 AM
Author Topic: Ringmaster Question (Answered thanks)  (Read 1707 times)
Offline Phil Coopy
« on: October 01, 2006, 01:49:14 PM »
Building an OTS legal Ringmaster by Hobby Fasteners.  There were two 1/4 x  1 1/4 wooden dowel pins supplied in the kit. I can"t find any application for them on the plans.  Anybody know?
Phil
« Last Edit: October 02, 2006, 06:51:56 AM by PHIL COOPY »
Offline Leester
Re: Ringmaster Question
« Reply #1 on: October 01, 2006, 02:39:21 PM »
These are for the arrow shaft push rod.
Leester
ama 830538
« Reply #2 on: October 01, 2006, 03:05:27 PM »
Wouldn't they be put through the fuse for attaching the rubber bands on the "shock absorbing" landing gear? I'm thinkn' so.
Offline Steve Holt
« Reply #3 on: October 01, 2006, 05:13:00 PM »
Leester is correct, they are for the arrowshaft pushrod assembly.  The pushrod assembly shown makes a light, strong, stiff pushrod.
The shock absorbing gear was on Goldberg airplanes.
Offline Phil Coopy
« Reply #4 on: October 01, 2006, 06:36:48 PM »
Thanks guys,  never thought of it because I usually use the plastic inserts normally supplied with arrow shaft pushrod kits.
Phil
Offline Ward Van Duzer
Re: Ringmaster Question (Answered thanks)
« Reply #5 on: October 02, 2006, 08:36:36 AM »
NEVER, repeat, NEVER use the plastic inserts on the DB push rods! No matter how much you sand them, no matter what kind of epoxy you use, they will break loose and your push rod comes apart! Seems there might be some release chemical in them, or? Planted two planes the same way :'(
Ward-O
