General control line discussion => Open Forum => Topic started by: Phil Coopy on October 01, 2006, 01:49:14 PM
Title: Ringmaster Question (Answered thanks)
Post by: Phil Coopy on October 01, 2006, 01:49:14 PM
Building an OTS legal Ringmaster by Hobby Fasteners.  There were two 1/4 x  1 1/4 wooden dowel pins supplied in the kit. I can"t find any application for them on the plans.  Anybody know?
Phil
Title: Re: Ringmaster Question
Post by: Leester on October 01, 2006, 02:39:21 PM
These are for the arrow shaft push rod.
Post by: wwwarbird on October 01, 2006, 03:05:27 PM
Wouldn't they be put through the fuse for attaching the rubber bands on the "shock absorbing" landing gear? I'm thinkn' so.
Post by: Steve Holt on October 01, 2006, 05:13:00 PM
Leester is correct, they are for the arrowshaft pushrod assembly.  The pushrod assembly shown makes a light, strong, stiff pushrod.
The shock absorbing gear was on Goldberg airplanes.
Post by: Phil Coopy on October 01, 2006, 06:36:48 PM
Thanks guys,  never thought of it because I usually use the plastic inserts normally supplied with arrow shaft pushrod kits.
Phil
Title: Re: Ringmaster Question (Answered thanks)
Post by: Ward Van Duzer on October 02, 2006, 08:36:36 AM
NEVER, repeat, NEVER use the plastic inserts on the DB push rods! No matter how much you sand them, no matter what kind of epoxy you use, they will break loose and your push rod comes apart! Seems there might be some release chemical in them, or? Planted two planes the same way :'(
Ward-O
