  • June 16, 2025, 06:32:49 PM
Author Topic: Work bench top  (Read 1092 times)
Offline Tom Rounds
  • lineflyer
Work bench top
« on: February 05, 2011, 05:35:16 PM »
 I am looking for something that I can use on my bench that I can stick pins in. For most larger wings I use a jig of some sort but I would like to be able to build right over the plans for some smaller designs. Years ago I could buy a product that I think was called Homosote. It came in 4'X8' sheets. It was like  the 24"" x 48" ceiling tiles that you can buy now. I went to both Home Depot and Lowes today and found out that I would have to buy a case package of the ceiling tiles. Needless to say don't have a use for that many. Anyone out there using some other product that would fill the bill?
AMA 7359
Offline Leester
Re: Work bench top
« Reply #1 on: February 05, 2011, 06:06:55 PM »
I use Dry wall, sheet rock whatever they call it in your area.
Leester
ama 830538
Re: Work bench top
« Reply #2 on: February 05, 2011, 08:57:31 PM »
Yep. You can stick pins in it, no problem.  And it's cheap to replace.  As long as you have a solid, flat, bench top, the thinnest is fine. (3/8ths" ??)
Big Bear
Offline Tom Rounds
  • lineflyer
Re: Work bench top
« Reply #3 on: February 06, 2011, 11:47:00 AM »
Thanks for the heads up on using sheet Rock.
Tom
AMA 7359
