  • July 19, 2025, 04:03:50 AM
Author Topic: Balancin Props  (Read 1048 times)
Offline Bootlegger
Balancin Props
« on: August 26, 2007, 06:27:31 AM »
   H^^ Mornin Guy's,
          First I must appologize for postin my question in the wrong place.
          I am curious about balancein props, I read to sand the "face" of the prop not the back.
          What is the reason for this ? My thinkin is that the airfoil is what makes the prop "work".
        Sanding the back changes the pitch though doesen't it ?
        Sure could use some help in this direction........ D>K
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Ralph Wenzel (d)
Re: Balancin Props
« Reply #1 on: August 26, 2007, 06:39:19 AM »
You're correct. For balancing, sand the "face" of the prop. You can ahieve a small amount of "re-pitching" through changing the angle of the "backside" of the prop, but any significant effort here will also reduce blade area.
Ralph Wenzel
AMA 495785 League City, TX
Offline Arlan McKee
Re: Balancin Props
« Reply #2 on: August 26, 2007, 07:42:41 AM »
Put on a latex glove and smooth super glue on the face of the light blade until it balances.
