  • June 30, 2025, 01:13:48 AM
Author Topic: Solvent for Sig Stik-it  (Read 1705 times)
Offline Andrew Borgogna
  • Andy
« on: November 21, 2007, 09:28:52 AM »
I am appling some Coverlite covering to my Lil' Zilch and have been using Sig Stik-it.  So far nothing I have used will clean the brush, I have tried Lacquer thinner and denatured alcohol neither of which does anything.  Does anybody know of a solvent that cuts this stuff?
Andy
Andrew B. Borgogna
  • Andy
Re: Solvent for Sig Stik-it
« Reply #1 on: November 21, 2007, 06:37:51 PM »
Thanks Ty, I will.
Andy
Andrew B. Borgogna
« Reply #2 on: November 22, 2007, 12:45:04 AM »
I just use throw away acid brushes. Never occurred to me to try to clean that stuff off a brush.
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #3 on: November 22, 2007, 08:12:57 AM »
Have you read the can to see if it says what to clean/thin with? Never used Stick-It but believe I remember the Balsa-Rite can saying use MEK.
Offline Peter Ferguson
« Reply #4 on: November 24, 2007, 10:50:49 AM »
When all else fails read the directions. The can says use Sig Butyrate Dope Thinner. The print is kind of small. I guess I'll start using that instead of Acetone.
Peter Ferguson
Auburn, WA
  • Andy
« Reply #5 on: November 26, 2007, 10:42:22 AM »
Ty
I used the acetone and it worked fine.  I appreciate you help.
Andy
Andrew B. Borgogna
