  • July 15, 2025, 07:47:17 AM
Author Topic: What is this covering?  (Read 1307 times)
Offline John Fitzgerald
  • No longer an AMA Member
« on: March 21, 2012, 04:38:08 PM »
I found two partial rolls of plastic film covering in my stash.  One is fluorescent yellow, the other fluorescent orange.  They are both white on the back side, and pretty thin.  No labels...I need to know the heat range...thinking of using over foam.
TIA.
Re: What is this covering?
« Reply #1 on: March 21, 2012, 04:42:12 PM »
Ultracote comes with a white backing material,, it feels kind of "krinkly" instead of soft like solar film or black baron film,,
they also make fluorescent colors,,
« Reply #2 on: March 21, 2012, 07:37:02 PM »
The backing that peels off is clear plastic.  The covering is actually whitish on the glue side.
Offline david beazley
« Reply #3 on: March 23, 2012, 05:24:01 AM »
Probably Monokote, I just used up the last of my fluorescent stash as well.
AMA # 2817
Online John Rist
« Reply #4 on: March 23, 2012, 09:11:53 AM »
Monokote usually has Monokote stamped on the edge of te film  ???
« Reply #5 on: March 23, 2012, 09:15:16 AM »
so you are saying that when you peal the CLEAR backing off, the back of the film is white, regardless of the top surface color?
then I have no clue,,
« Reply #6 on: March 23, 2012, 11:13:38 AM »
Yes, glue side is white regardless of the top surface.
No label alnog the edge like MonoKote and no watermarks that I can find.  It's about 12 years old or so, but was well stored and still good.
Offline Steve Hines
« Reply #7 on: March 23, 2012, 03:58:11 PM »
Can't think of the name, but World Models sells a brand with white on the back. They use to make Sigs ARF.
