  • July 04, 2025, 12:10:00 PM
Author Topic: Assembly Instructions for Mo Best  (Read 1521 times)
Mike Griffin
« on: October 30, 2014, 04:46:56 PM »
I have the instructions from page 11 on but need the very first part of the assembly instructions up to page 11.  Larry did this in a PDF file and if anyone has it, could you please e mail it to me at mikegriffin1947 at cox dot net. mikegriffin1947@cox.net
thank you
Offline Leester
Re: Assembly Instructions for Mo Best
« Reply #1 on: October 30, 2014, 05:07:19 PM »
Mike, Just sent them to you..
Leester
ama 830538
Mike Griffin
« Reply #2 on: October 30, 2014, 05:43:46 PM »
I got it Lee.  Thank you
Offline Brent Williams
Mike Griffin
« Reply #4 on: October 31, 2014, 07:54:00 AM »
Thank you Brent
Offline Robertc
« Reply #5 on: October 31, 2014, 08:27:55 PM »
Which fuse version you building?  Larry had at least three different versions.  I have Larry's computer files so if you have instructions for a different version, I should be able to help.  First version is just balsa fuse.  Second version is sheeted
from the back of the wing with the sheeting at 60 degree angle and third version has convex formers sheeted with either 1/32 or 1/64 ply.  The last version makes a very stiff fuse which was the idea.  Each version was suppose to be stiffer than the previous.
« Reply #6 on: November 01, 2014, 08:59:11 AM »
I now have the file on a disc and have read it.   Larry was beyond his time.   Need to get a set of plans.   Now will a LA 46 be enough power.   I think it would with the right venturi and prop.
Mike Griffin
« Reply #7 on: November 01, 2014, 10:18:59 AM »
I just sent you a personal message Robert.  Thank you
Offline Leester
« Reply #8 on: November 01, 2014, 11:45:12 AM »
Doc, LAS 46 is just fine. That's what I had on mine and worked great.
Leester
ama 830538
Offline Robertc
« Reply #9 on: November 01, 2014, 12:00:01 PM »
I ran a 40FP on my first three MoBests and it worked fine.  The past two have had LA 46.  I think it is a great combo.
Larry ran 40 FPs, Silver Fox 40 and a Super Tiger 51.  All worked just fine.
« Reply #10 on: November 01, 2014, 05:10:36 PM »
Thanks for the info guys as I just found my plans when I went to do some more tidying up in the shop.
