  • June 26, 2025, 11:01:57 AM
Author Topic: Ohlson and Rice screws!  (Read 1743 times)
Offline Andrew Tinsley
« on: September 16, 2009, 06:22:26 PM »
Hello Everyone,
                      In a previous post, I was helped out, as to the type of screw threads that were commonly used in old ignition engines. I had a very helpful response, McMaster Carr were said to be the best supplier. Thought I would wait until I was in the US before ordering in bulk! Imagine my consternation when I tried to get 2 to 2.5 inch long 2-56 bolts (screws) and nuts, for a couple of Ohlson 60s.........couldn't even find any 2-56 screws in the online catalogue. Is it just me or don't they stock 2-56 nuts and bolts? If not, is there anyone else that does?
Thanks in advance,
Andrew.
BMFA Number 64862
Offline Leester
Re: Ohlson and Rice screws!
« Reply #1 on: September 16, 2009, 06:27:23 PM »
Try Micro Fasteners they have them www.microfasteners.com/index.cfm
Leester
ama 830538
« Reply #2 on: September 16, 2009, 06:32:34 PM »
Thanks Leester!
                      I knew that there used to be (?) a stunthanger sponsor that did fastners. Couldn't for the life of me remember the name, senility is creeeping up!
Andrew.
BMFA Number 64862
« Reply #3 on: September 16, 2009, 06:46:39 PM »
Hi Leester!
               Just looked at Microfastners, longest 2-56 screw that they do is 1.5 inches long. Can anyone tell me offhand if the O&R 60 does have 2-56 screws holding the crankshaft assembly to the cylinder assembly?
Andrew.
BMFA Number 64862
Dave Adamisin
« Reply #4 on: September 16, 2009, 07:17:57 PM »
I dont have one here to look at but I think that they are 4-40's
« Reply #5 on: September 16, 2009, 07:55:15 PM »
Andrew...If you have the old screws, measure the major diameter. They should be about .112" diameter if they're 4-40's, which I think is likely. If you don't have any correct screws, then measure the holes they go through. The holes should be around .120" or 3mm. If the holes are bigger, (.135"?), then maybe you could get 3mm screws to use? And if length is a problem, just put an elastic lock nut on each end of a piece of "all-thread".  D>K Steve
« Reply #6 on: September 17, 2009, 08:13:49 AM »
 Thanks guys!
                   The O&Rs are back in the UK so I can't check the thread or hole sizes. I am sure that the O&R 19 and 23s are 2-56 but I have this sneeking feeling that the O&R60 may have bigger bolts!
  Serves me right, I should have checked before I left home! I am sure someone will put me right!
Thanks everyone for all your help,
Andrew.
BMFA Number 64862
« Reply #7 on: September 17, 2009, 08:34:16 AM »
Andrew:
Here's a different approach, I found this forum that is for old engine enthusiasts.  You can probably find someone there who can answer your O&R questions
http://www.modelengine.org/forum/index.php
Offline Ralph Wenzel (d)
« Reply #8 on: September 17, 2009, 10:10:46 AM »
Contact Morrie Lavinthal via lsanmo (at) aol (dot) com. He offered a "new" reproduction O&R .60 a couple of years ago and probably has some screws left over.  My recollection is that the screws you seek are actually Filister-head 4-40's not 2-56's, but I could be wrong.
Ralph Wenzel
AMA 495785 League City, TX
« Reply #9 on: September 17, 2009, 10:18:44 AM »
Andrew.  I have three O&R 60 here.  The stock screws are 4-40 X 2".  Not sure just where you are now.  If in the US, these are easy to find at specialty "fastener" stores.  If you are really stuck, let me know and I'll get some for you.
« Reply #10 on: September 17, 2009, 10:48:12 AM »
Andrew, I think you want 4-40s, here is a link. Pick machine screws and then filister head and then just go on down the page, they're there.  They do have 2-56s but only up to 1"
http://www.mcmaster.com/#machine-screws/=3o7il7
« Reply #11 on: September 26, 2009, 03:26:11 PM »
Thanks for the help everyone!
Andrew.
BMFA Number 64862
