  • July 30, 2025, 12:21:01 AM
Author Topic: Anyone interested in new gear?  (Read 4493 times)
Offline John Sunderland
« on: April 09, 2012, 09:31:25 PM »
I am putting out a feeler here guys. Here is the situation. I have become employed at a first rate rapid prototyping shop in the last six months. They are plenty busy and not looking for business.
I have access to molding equipment of a very high caliber. From 3D printers to CNC machines (plastic only) and several autoclaves as well as design equipment above and beyond CAD. I also have the bosses blessing for tooling use but mold casting materials will cost.
So what I really want to know is how much interest there is? For new carbon fiber gear, bellcranks, old single style control horns for nonflapped designs, cowls and wheel pants...etc.
A few years back I called Dan Winship and asked if he were going to make any more stunt equipment, gear in particular. He said no and also said he did not care if i made copies of some of his stuff. As most will attest... very high quality, like jewelry! LL~
I will have to touch base with Dan again, however I will have the ability to make dead on copies of just about anything, and make it from and carbon/epoxy or other urethane materials. Some that will will even simulate rubber quite well for somebody who might want something for scale...untested as to durability thus far but worth exploring.
Talk to me fellas! H^^
Offline Douglas Ames
Re: Anyone interested in new gear?
« Reply #1 on: April 09, 2012, 09:52:15 PM »
(1) A Carbon Fiber EZ-Just! - with hardpoints instead of cables
(2) Narrow side-by-side line reels so you can keep your lines from tangling. 2 & 3 line versions, standard design (plastic)
AMA 656546
Offline bill bischoff
« Reply #2 on: April 09, 2012, 10:28:42 PM »
Carbon props?
Offline Dave Denison
« Reply #3 on: April 09, 2012, 10:33:25 PM »
John.
Thanks for the great opportunity to move ideas forward. Here are a couple of mine.
(1)  Moulded, "Veco style" spinners, especially the needle nose style.
(2)  A line of Cl wheels, thin and very light.
(3)  Something to contain mutable line sets.
Go forth and create
  Dave.
ama 41041
« Reply #4 on: April 09, 2012, 10:39:20 PM »
 Needle nose spinners in carbon fiber, the long Randy Smith style.
« Reply #5 on: April 10, 2012, 12:13:15 AM »
I like the way you think but I would probably want to do handles out of urethane with some carbon re enforcement possibly. Makes for a pricy handle with that much carbon and epoxy. Besides there are plenty of good handles out there now. The two sided line real is a killer idea!... But also probably best built out of a cheaper material. The urethanes we use currently are on par with what houses your computer, most medical equipment and has been used for military applications.
John.
Go forth and create
  Dave.
Stunt wheels is a great idea! We have been molding this two part black silicone to make rubber pads for digital imaging equipment... I just need to test it out. Urethane bushed hubs could work... weight could get goofy unless I opt for a Thin Urethans hub done ultra slim with the rubber I mentioned for the tire.
 Also of note here, finding a manufactured prop with a hub that WILL fit under a Veco NN spinner has been a challenge... lends itself toward what ideas might be considered for a prop as well.
I liked STalker Modusa NN spinner but never used one. Back when I used Stalkers we gave the extras out as door prizes at our contests.
The Stalker props were nice too but didnt do well with repitching and split easily. For me what they offered never worked well for my airplane, but others loved the props. Not sure if Kaz still stocks that or not but I will look into it.
Props are a pain and there are plenty out there... going full tilt on this would be laborious. Maybe just some specific offerings or custom orders.
« Reply #6 on: April 10, 2012, 09:26:52 AM »
John,
there could be applications in many areas.
Be interesting to see what products, at the moment, are being produced with the equipment you have access to?
I have a few things in mind.
Charles
« Reply #7 on: April 10, 2012, 07:35:24 PM »
For my carrier lines, to keep the throttle line separate from the control lines, I glue and bolt two SIG Mfg reels together.   H^^
Offline Hoss Cain
« Reply #8 on: April 11, 2012, 12:29:54 AM »
WHAT HE SAID!  #^
Also a line of Spinners with a molded style more like the ME-109, P-51, Hurricane, Spitfire, etc. Good Aluminum backplates and propnuts avaiable. Of course at a price less than the first-born such as that other well-known spinner supplier.  %^@
Horrace Cain
AMA L-93 CD and Leader
« Reply #9 on: April 11, 2012, 01:00:34 AM »
John,
Charles
Great idea Charles. Go to FormulaPrototypes.com. to get a birds eye view of what is being built here currently. Most equipment shown here are digital imaging devices for the medical field. Some comes out of silicon valley, others have miltary applications/aspirations. Fortunately, this company not only does the proto work, but small production runs for sales applications and demonstrations, initial sales. Then possibly it all goes to china for tooling... if the gagdet sells.
Offline John Cralley
« Reply #10 on: April 11, 2012, 10:50:22 AM »
John,
A line of light spinners for the APC pusher props that we electric control line folks are using would be appreciated!!!  y1
John Cralley
AMA 52183
Central Illinois
Offline Dave Heinzman
« Reply #11 on: April 11, 2012, 11:35:11 AM »
Hi John, congrats on you new employment! I would be interested in at least two of the landing gears that Dan used to make. I think they had 3 screws instead of 4 on the fuselage mounting plate.
Dave Heinzman
« Reply #12 on: April 11, 2012, 12:48:11 PM »
How about CF gear with built in wheel pants?
What about a CF nose gear?
Motor cruch with some type of rubber damping to reduce vibration ?
A REAL CL field box.
Let me think some more.
steven yampolsky
« Reply #13 on: April 11, 2012, 01:28:33 PM »
Oooh! major drool factor!
« Reply #14 on: April 11, 2012, 03:51:17 PM »
Hi John,
I would love to see Dan Winship's bell cranks back in production if the cost can be kept down to manageable.  With out the Lead Outs attached would be fine.
« Reply #15 on: April 11, 2012, 05:28:21 PM »
First off, I"m thinking CL handles, made in halves with the metal CNC'd.
Modeler does the assembly.
That would be a good start because a bunch would be sold.
Charles
« Reply #16 on: April 11, 2012, 06:00:02 PM »
I would be interested mostly in repros of the Winship LG's.  I've got one on a plane, and it works most excellently... not too stiff, not too soft, etc.  CF Spinners would be cool, of course, but a CF landing gear that was designed to mount in the wing would be even better.  H^^ Steve
« Reply #17 on: April 11, 2012, 06:45:51 PM »
 Carbon fiber Paul Walker B-17 and/or Billy Werwage P-47 kits. ;D
« Reply #18 on: April 11, 2012, 07:16:54 PM »
HI John,
Did I mention Winship bell cranks?
Offline Larry Cunningham
  • Red Hot Lover
  • Klaatu barada nikto my ass
    • Stephanie Miller
« Reply #19 on: April 12, 2012, 06:33:50 PM »
A carbon fiber (or APC composite material) Rev-Up 11 x 6 EW (and other) prop!
A carbon fiber girl friend or wife!!!
A carbon fiber wheel chair, that weighs about 18 lbs, folds nicely, doesn't pinch {ever!} and costs under $100 {or less if you can't afford that}..
A carbon fiber cure for diabetes. And heart disease. And cancer. And lethargy, stupidity, hatred, greed, ...
Oops. (He won't be able to scan all that stuff!) '->
L.
"Advertising may be described as the science of arresting human intelligence long enough to get money from it." -Stephen Leacock
« Reply #20 on: April 12, 2012, 06:56:35 PM »
NOW you're talking Wayne!!!!!   Carbon fuselages and wings would be sweet too...
« Reply #21 on: April 13, 2012, 02:49:48 AM »
 :) Let me get more homework out of the way. Explore our possibilities and determine what is cost effective. From you, I know what is most wanted and know what was/ is needed. There are several items we will explore, props being one, but liability is an issue in this matter. I will not visit that right now, but I have ideas. ;D
« Reply #22 on: April 13, 2012, 02:53:54 AM »
Go easy ! %^@ I already have friends back east doing that for themselves. I just want to make the necessary accessories.
Offline Steve Fitton
« Reply #23 on: April 13, 2012, 07:07:34 AM »
How bout copies of the Howard Rush landing gear that Bruce Perry uses on his Jester series?
  • Red Hot Lover
    • Stephanie Miller
« Reply #24 on: April 13, 2012, 01:14:32 PM »
Copies of Howard Rush!
Oh yeh..
L.
"Complex problems have simple, easy to understand, wrong answers." -Grossman's Law
« Reply #25 on: April 13, 2012, 01:26:55 PM »
Did anyone mention Dan Winship's Bell Cranks yet? ???
LL~ LL~ LL~
