  • July 14, 2025, 08:53:37 PM
Author Topic: Anybody recognise this crankcase?  (Read 1441 times)
Offline pipemakermike
« on: January 17, 2015, 06:03:57 AM »
Bought from California_Dan via Ebay.  Should have been an Atom 09 crankcase.  I have to decide if I can make the rest of the parts to complete an engine.  Also, can anyone suggest what the thing under the crankcase is for?  It looks like it opens a small hole into the crankcase.  Is it a form of throttle?  or possibly a shutoff?
I think that the case is Magnesium.
Pictures:-
And
added:
« Last Edit: January 17, 2015, 10:01:24 AM by pipemakermike »
Mike Nelson
Offline rustler
Re: Anybody recognise this crankcase?
« Reply #1 on: January 17, 2015, 01:38:47 PM »
...what the thing under the crankcase is for?  It looks like it opens a small hole into the crankcase.  Is it a form of throttle?  or possibly a shutoff?
Probably a bleed valve for when you flood the c/case. There's at least one vintage engine with this feature, but blowed if I can remember the name. Someone will.
Ian Russell.
Online Gerald Arana
« Reply #2 on: January 17, 2015, 02:56:49 PM »
I believe that is a 1947 "Mite Diesel" 09 as shown on page 73 of my Andersons 4TH Edition Engine "Bible".
It has the venturi the same height as the top of the CC, four cylinder holes (same as yours), the valve at the bottom of the CC and the ring looking thing at the front of the CC.
Good luck finding parts for that one!
Cheers, Jerry
PS: The mounting holes look the same too.
Offline Norm Furutani
« Reply #3 on: January 17, 2015, 08:58:38 PM »
« Reply #4 on: January 18, 2015, 02:56:00 AM »
Thanks everyone.
Knowing the name makes searching soooo much easier<g>
So here is what I have found out:-
I think that it is indeed a Mite 0.099 (1.62cc) Diesel designed by one Howard Mandeville, and first introduced by Walt Schroeder's kit company, Eagle Mfg. Co. of Brooklyn around 1947.
I have found a lot more information on line and some pictures of the complete engine:-
Interestingly the Alan Ortof review calls the valve under the crankcase a "throttle Valve" where other reviews think that it is a drain valve for a flooded engine.
There was also a glow version:-
Mike Nelson
« Reply #5 on: January 18, 2015, 09:13:40 AM »
Is that magnesium?
« Reply #6 on: January 18, 2015, 01:12:04 PM »
The ad clearly states a "positive cut-off" feature.  The valve can be opened to stop the engine.
Offline Chris Wilson
« Reply #7 on: January 18, 2015, 04:49:08 PM »
The ad also clearly states that it can be also a throttle as it can progressively bleed off lower crankcase pressure long before stopping the engine.
(Perhaps an interesting addition to a stunt glow instead of using a bell crank activated exhaust throttle?)
MAAA AUS 73427
« Reply #8 on: January 19, 2015, 05:59:37 AM »
Is that magnesium?
Yes it appears to be and looks as though the case has never been used.
I will probably make all the missing parts but it is not at the top of my do list for this year but I have had a quick model to test the feasability.  Is there anyone out there who has one?
Mike Nelson
