  • August 02, 2025, 04:16:07 AM
Author Topic: Old Photo from maybe 50s or 60s?  (Read 2873 times)
« on: January 05, 2018, 06:28:06 PM »
I saw this on facebook book and was under OT RC but this looks more like a OT CL plane. I don't see any leadouts so maybe is RC.
Any one know?
Re: Old Photo from maybe 50s or 60s?
« Reply #1 on: January 05, 2018, 06:33:02 PM »
 There's no leadouts showing because the inboard wing is gone and the photo is looking at the bottom of the airplane. There's a line reel in the guys left hand too. Hard to tell, but looking at the stab/elevator outline I'm gonna say it's what's left of a Zilch?
 Also, I don't think we'd be struggling with most contest attendances like we do if there were still gals like that hanging around!  ;D
Offline Mike Keville
« Reply #2 on: January 05, 2018, 06:44:13 PM »
Plymouth Internationals, Detroit - 1950s.  Lil' Duper Zilch entry in Combat?
Offline Larry Fernandez
« Reply #3 on: January 05, 2018, 09:11:29 PM »
 I believe that it’s the outboard wing that is missing.
If you look closely at the rudder, you’ll see that it is offset for clockwise flight.
Larry, Buttafucco Stunt Team
« Reply #4 on: January 05, 2018, 09:19:26 PM »
 Yep, a closer look says Larry's right, it's the outboard wing that's toast.
Offline Doug Moisuk
« Reply #5 on: January 05, 2018, 10:29:07 PM »
And you guys are examining the airplane? What airplane.
Doug Moisuk
MAAC 3360L
Offline Frank Imbriaco
« Reply #6 on: January 06, 2018, 04:26:49 AM »
They sure made them cute back then. I like 'em without ink and no piercing.   #^
Offline Steve Lotz
« Reply #7 on: January 06, 2018, 04:57:29 AM »
That is absolutely a Zilch. Looks kinda big for a Li'l Duper-I'm gonna say it's a Super Duper Zilch.
Offline peabody
« Reply #8 on: January 06, 2018, 05:39:18 AM »
Hanging in Rich Giacobone's basement are a pair of vintage combat planes....one flew clockwise (Rich) and the other counterclockwise (Gene Martine)....apparently it was fine then whichever way you flew....
Have fun!
Offline Tim Chenevert
« Reply #9 on: January 06, 2018, 05:44:38 AM »
What plane? Lol  Tim
Baton Rouge Bi-Liners
AMA 179681
Offline Craig Beswick
« Reply #10 on: January 06, 2018, 07:21:34 AM »
You guys absolutely certain it is control line?
I'm only a novice but it is an engine in his left hand certainly not a line reel.
If it is set up for clockwise rotation then isn't the inboard wing the one that is not damaged? I can't see any lines coming out of it.
Either way the girls are cute!
Craig
AUS 87123
"The Ninja"
Offline Andre Ming
« Reply #11 on: January 06, 2018, 07:54:07 AM »
Is that a bellcrank hanging out of the hole on the underside of the wing, where the fuse is split?
« Reply #12 on: January 06, 2018, 08:29:42 AM »
Definitely CL,  Zilch I'd agree.  RC planes of that day were largely single channel and looked more like an old time free flight airplane- bigger and with high wing and dihedral.  Yeah the airplane looks interesting too I guess.  Maybe I'll look at it in a minute.
Offline Gerald Arana
« Reply #13 on: January 06, 2018, 08:35:46 AM »
Ditto!  LL~
Jerry
« Reply #14 on: January 06, 2018, 08:42:31 AM »
Craig
Craig, Do you fly RC? A ship with NO ailerons or dihedral will not turn with rudder only. It will yaw and go straight........into the ground. Don't ask me how I know.
Jerry
Offline Roger Vizioli
  • CLiner
« Reply #15 on: January 06, 2018, 08:53:51 AM »
Some more info to add to the questions/discussion:
  I competed , as a Junior, at the "5th International Model Plane contest" in Detroit. Pic is at the Plymouth Internationals (5th) , Detroit, Summer 1953.
   My T shirt was the same as shown in pic., watched G. Aldrich fly and L. Andrews (RC Trixter Beam) fly
   so, if my mind is still working after xx years- re the pic.
      The plane, if a Zilch, is shown right side up, see triangular shaped turtle deck aft of cockpit, also shows some light colored trim aft of cockpit area which matches that shown on "removed" wing.
comment re rudder offset supports this thought.
      Still cant locate lead outs or bellcrank.
      And yes!       Yes,  there were many pretty young "girls" everywhere. :-)
« Last Edit: January 06, 2018, 09:23:26 AM by Roger Vizioli »
Roger Vizioli
AMA L-2408
Florida/Space Coast
Offline Gordon Van Tighem
« Reply #16 on: January 06, 2018, 10:34:11 AM »
Interesting background video of the second Plymouth International. His shirt identifies the picture as from the fifth.
G
Gord VT
MAAC 3738L, Life Member
AMA C3738L
« Reply #17 on: January 06, 2018, 11:03:57 AM »
Hey we still have cuties at contests around that look like that.   And that has to be a control line plane.  Radio control wasn't advance enough to fly a plane like that.  Now about the young ladies,  great to look at but else are they good for? LL~ LL~ LL~
By the way does any body recognize the young man? D>K
Offline don boka
« Reply #18 on: January 06, 2018, 11:07:53 AM »
Does anybody remember Theresa Grish from the Grish propeller clan?
Good looking girl but a bit older than me.
Could be wrong but I think they were the Tornado prop family.
Don Boka.
Offline Ara Dedekian
  • Ara Dedekian
« Reply #19 on: January 06, 2018, 11:47:09 AM »
        I see a pushrod still attached to the elevator where the control horn would be. It's curved out to the 2nd rib from the fuselage, under the intact wing. I'm guessing that's where the bellcrank and leadouts are, hidden from the camera.
        Ara
Offline Tony Drago
« Reply #20 on: January 06, 2018, 01:34:39 PM »
 Ara.
You are correct. I magnified  the picture up 1000. In the pilots left hand is what's left of the engine and the front of the fuse.
 Also looks like it was being flown clock wise
« Reply #21 on: January 06, 2018, 09:07:28 PM »
 OOPS, mistaken again here. Zooming in even more that is definitely an engine and not a line reel. Them purty gals must be distracting me.  ;D
« Reply #22 on: January 07, 2018, 02:40:25 PM »
It was quite common for the Zilch to shed a wing in flight.  The balsa spars in the center of the airfoil gave not much strength.  After my first SD Zilch lost a wing, I built another using hardwood spars.
