  • June 27, 2025, 07:47:33 AM
Author Topic: Ambroid glue  (Read 2240 times)
Offline Tony Drago
Ambroid glue
« on: March 29, 2017, 05:04:09 PM »
Ebay. Not mine
Ambroid Original Cement 1 gal can unopened
282408139439
Offline Lyle Spiegel
Re: Ambroid glue
« Reply #1 on: March 29, 2017, 05:51:25 PM »
Ambrulose is available as a  nitrocellulose based solvent, I think sold for guitar builders / or attaching feathers to home made archery arrows. Anyone know about this stuff?  Same as our beloved Ambroid?
Lyle Spiegel AMA 19775
Offline Jack R
  • John Rusnak
Re: Ambroid glue
« Reply #2 on: March 29, 2017, 06:03:38 PM »
read somewhere that walmart sells a cement with 527 in the name that is supposed to be very similar to sigment..might be worth a look now that ambroid is hard to find
Offline david beazley
Re: Ambroid glue
« Reply #3 on: March 29, 2017, 06:21:48 PM »
I bought some Abrulose from a guy over on Hip Pocket. Seems to be about the same as Ambroid. I use it for FF models and I like to use it for joining balsa sheets as it sands real well. Thin it with acetone. Supposedly used in full scale wood AC but only comes in 5 gallon containers. This guy repackages it in 2oz and 4oz bottles. I like it. Tastes like Ambroid when you chew it off your fingers n~
AMA # 2817
Re: Ambroid glue
« Reply #4 on: March 29, 2017, 06:29:00 PM »
This is a bottle of "Ambrulose" cement. Each is 4.2oz HDPE thick refill bottle. This is the same cement as the old Ambroid@ cement which is no longer available. This is a pure Nitrocellulose. This adhesive is a favorite for arrow fletching, wood model building and in general, very good wood and porous material adhesive. Dries very hard but not brittle. If you build small scale flying models, fletch arrows vintage wood model kit railroad cars or any other wood projects than this is the right adhesive/cement. This is a refill bottle for refilling the smaller 2oz dispensing bottle.
