  • June 29, 2025, 09:50:44 AM
Author Topic: Aluminum Question  (Read 1129 times)
Aluminum Question
« on: November 12, 2010, 07:43:50 PM »
For all you metallurgists; for our applications such as engines, does 356 HAVE to heat treated and, is 713 actually a better material for engine cases than 356?
Re: Aluminum Question
« Reply #1 on: November 12, 2010, 07:58:55 PM »
In 36 years of Aerospace and commercial machining, I'm pretty certain that all the castings I ever machined or inspected were 356, if that means anything.  :-\ Steve
« Reply #2 on: November 12, 2010, 08:18:53 PM »
From comments I've seen, as-cast aluminum is soft and "gummy".  Even if strength weren't an issue operationally, soft gummy aluminum is a pain in the wazoo to machine -- any manufacturer is going to want to heat treat it just to make it machine nicely.
Dunno about the alloy -- what makes you think 713 would be better?
« Reply #3 on: November 13, 2010, 12:38:08 AM »
Didn't mean better, just 713 doesn't seem to require post cast heat treat. Somewhat more brittle than 356.
