  • July 25, 2025, 08:54:51 AM
Author Topic: ACRO-60 BUILDING SEQUENCE PHOTOS  (Read 1061 times)
Offline Ted Winterman
« on: March 26, 2009, 10:33:34 AM »
More wing details.
     Tip weight container is light weight aluminum cigar holder. Plastic tube eliminates vibrations/movement. Cap screws on/off. Dense foam
takes up 2/3rds of tube to keep tip weight towards tip.
     Slider for leadout adjustment.    D>K
Offline Michael Floerchinger
    • Arcadia Acres
Re: ACRO-60 BUILDING SEQUENCE PHOTOS
« Reply #1 on: March 26, 2009, 11:51:35 AM »
Looking good Ted!
One of these I will start on another
  • Gravitywell
« Reply #2 on: March 26, 2009, 12:13:57 PM »
Hi Ted....looks real nice.  If I may make a suggestion.....cut a small peice of cork to fit inside the cap of your weight box/tube.  Otherwise the tip weight may eventually come right thru the cap.  Don't ask me how I know this! LOL
Glenn Reach
Westlock, Alberta
gravitywell2011 @ gmail . com
« Reply #3 on: March 26, 2009, 01:26:11 PM »
Hi Gravitywell.
    I failed to mention that I made a steel disk that I JB welded to the inside of the cap. But I will take your advice and CA some cork
to the inside also.
    Thank you!   H^^
  • Gravitywell
« Reply #4 on: March 26, 2009, 02:09:00 PM »
yeah....it sucks when you loose your tip weight in the middle of an overhead eight! LL~ H^^
Glenn Reach
Westlock, Alberta
