  • June 20, 2025, 10:35:09 PM
Author Topic: Davis Special II  (Read 1854 times)
Offline Allen Goff
  • Charter Member
    • Fellowship of Christan modelers
Davis Special II
« on: March 22, 2020, 12:56:19 PM »
I started this project last October and this is where I'm at so far.
Weight is 54.1 ozs. in primer and everything installed.
Bob Hunt foam wing, Tom Morris controls, all carbon .02 vale covered and a Randy Smith P A .75RE for power with a Bob McDonald 3 blade prop.
I just came up stairs from the paint room after applying the base coat white. I have not yet decided on the graphics but it will be a combination of red white and blue and maybe some light touches of purple and green. And since this is a Roger Wildman designed airplane I must put some Diana cream on it somewhere, LOL....... LL~ LL~ LL~
Be safe, stay calm, we'll make it through this.
Blessings
Allen
Re: Davis Special II
« Reply #1 on: March 22, 2020, 03:38:32 PM »
You are right - no Diana cream, no fly!  Lookin' goooooooood. H^^
« Reply #2 on: March 22, 2020, 04:47:38 PM »
54.1?   Allen where did you get the unobtainium?   That looks very sharp!
Offline Allen Goff
  • Charter Member
« Reply #3 on: March 22, 2020, 05:05:31 PM »
Dave, 54.1.......came in part from a very light wing Bob made. I also had some nice light wood and had little need to go back and fix imperfections. The primer was a lighter paint then I’ve used before so now I hope I can put on light graphics and clear. I’m praying for 60ozs, we’ll take what we end up with.
Offline Bill Hummel
« Reply #4 on: March 22, 2020, 05:17:44 PM »
Allen, nice job, looking really good!  Interested in what primer you used?  Thanks!
ama 72090
Online James Mills
« Reply #5 on: March 22, 2020, 06:11:42 PM »
Nice, Roger would be proud.
James
AMA 491167
Offline John Leidle
« Reply #6 on: March 23, 2020, 01:48:18 PM »
  Hey Allen,
  If you get that beauty  out here to th Contest in Roseburg   I'll launch & be your pickup man.... is that 54 ounces with the engine & tank?
         John L.
Online Crist Rigotti
« Reply #7 on: March 23, 2020, 04:25:40 PM »
Looks very nice Allen.
Offline Allen Goff
  • Charter Member
« Reply #8 on: March 23, 2020, 04:50:07 PM »
Thanks everyone for all the kind words
John, yes it is with the engine and tank installed. Now  comes the big questions, how much weight will I add with paint, graphics and 4 to 5 coats of clear. Praying I can do all that for under 10 ozs.
Blessings
Offline Paul Walker
« Reply #9 on: March 23, 2020, 06:29:48 PM »
  Hey Allen,
         John L.
IF there will be a Regionals. I estimate this lockdown could last easily into May, if not further. John T indicated they will make a decision in very early May as to a go/no go.
Hope we do though!
Offline John Leidle
« Reply #10 on: March 23, 2020, 06:43:04 PM »
   Paul,
   Was speaking  as an optimist... for sure it could be cancelled.  Maybe a few contest will be relocated to September ?
    Allen,
   I think you will put a much lighter finish than 10 ounces on that plane.
         John L.
« Reply #11 on: March 23, 2020, 06:57:59 PM »
Allen,
What is the wing area you are working with? What finish are you using - dope or base coat? What clear coat do you plan on using.
Best,    DennisT
Offline SteveMoon
    • www.ultrahobbyproducts.com
« Reply #12 on: March 25, 2020, 11:21:49 AM »
Looks great Allen!
« Reply #13 on: March 27, 2020, 09:36:22 AM »
Looking good!
What was the primer you used?  Over what base coat?
Thanks!
Offline Allen Goff
  • Charter Member
« Reply #14 on: March 28, 2020, 08:47:05 AM »
One more strip to paint on plus the name "Davis Special too" and my AMA number. Inking, four coats of clear, then the fun begins, :P wet sanding 1200, rubbing out. So far 60.1 ozs.
Blessings
Allen
« Reply #15 on: March 28, 2020, 11:38:06 AM »
Hey Pard, I love the paint scheme, simple but elegant!  (Now, where does the Diana cream go?) VD~ H^^
Offline Allen Goff
  • Charter Member
« Reply #16 on: April 03, 2020, 01:52:31 PM »
61.0 ozs. ready for clear.
« Reply #17 on: April 04, 2020, 07:57:38 AM »
Oh yeah!!!!!!!!!!!!!!!!!! H^^ H^^ H^^ H^^
