Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
July 08, 2025, 07:44:44 AM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Open Forum
(Moderators:
RandySmith
Steve Berry
...a sperement...
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: ...a sperement... (Read 1562 times)
Bootlegger
22 supporter
Trade Count:
0
Admiral
...a sperement...
on:
July 27, 2012, 09:58:32 AM »
I am gonna conduct a sperement on spectra 30lb test lines.
First is soak some of the lines in fuel overnight to check the effect..
Second is making the line ends up like we do on steel cables, wrapping A M A style...
Third all tests will be using 1/2A models for safety..
Hopefully I will have some results by mid week..
Logged
8th Air Force Veteran
Gil Causey
AMA# 6964
Tim Wescott
25 supporter
Trade Count:
0
Admiral
Re: ...a sperement...
Reply #1 on:
July 27, 2012, 12:13:19 PM »
Do some where you tie the lines off to a bight (I think that's the right word) -- I've heard a rumor that that's the "AMA way" for Spectra-type line, and at any rate I've seen comments that that's the 'right' way to do it.
My personal experience is tying it off to miniature line clips (which are very bight-like); I've only had one failure and that was after the model went slack on the lines and made it almost halfway across the circle before it came tight again with a huge jerk -- and the crash was on a subsequent flight on the same lines (I think I learned something from that).
Logged
David Russum
AMA Member
Trade Count:
0
Lieutenant
Reply #2 on:
July 27, 2012, 12:34:00 PM »
Gil, get in touch with Bill Wilson here in Dallas. He has done lots of tests with knots, connections, breaking strength, etc. He probably has the most experience of anyone around here with Spectra lines.
Logged
AMA #335952
Douglas Ames
2014 Supporters
Trade Count:
0
Admiral
Reply #3 on:
July 27, 2012, 12:44:40 PM »
I like sperement gum!
The little 1/2A job I used to have had fishin' lines (spectra).
The knot was critical, especially when lubed with castor/ engine exhaust. If anything is going to fail it will be that.
Logged
AMA 656546
Mark Scarborough
2015
Trade Count:
0
Admiral
Reply #4 on:
July 27, 2012, 01:20:52 PM »
you might also get ahold of the combat guys, they have been sperimenten with them thar spectral lines too,,
Logged
Larry Renger
21 supporter
Trade Count:
0
Admiral
Reply #5 on:
July 28, 2012, 05:56:06 PM »
If you do use knotted ends, wet the thread before pulling it tight. It will pull tighter without abrasion. I have had no further failures in knotted ends as I did with dry tying.
Logged
BTW, Dracula Sucks! A closed mouth gathers no feet!
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Open Forum
(Moderators:
RandySmith
Steve Berry
...a sperement...
