  • July 12, 2025, 05:12:26 AM
Author Topic: ...rats...  (Read 2256 times)
Offline Bootlegger
...rats...
« on: December 21, 2012, 02:36:25 PM »
  Mixed some finishing resin, mixed it well, brushed it into tank/engine compartment, as well as the nose section of the top block.
  This was two days ago, the engine/tank section is cured, but not the nose section of the top block.
 Brought the parts into the house to check if the warmth here will help w/curing.
  Any other suggestions???
   Thanks,          n~
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: ...rats...
« Reply #1 on: December 21, 2012, 03:01:29 PM »
Try a heat gun, but don't get it too hot.
This is a strange situation however.
Was there anything on the nose block that might contaminate the resin?
Offline Bootlegger
Re: ...rats...
« Reply #2 on: December 21, 2012, 03:34:29 PM »
  Thanks for the reply Randy, as to contamination on the nose block, I really doubt that.
  I am gonna leave it here in the house overnight, then check.
  Again thanks, and Merry CHRISTmas...    n1
Gil Causey
AMA# 6964
Re: ...rats...
« Reply #3 on: December 21, 2012, 03:40:20 PM »
Bootlegger,
What was the product brand you used?
Charles
Re: ...rats...
« Reply #4 on: December 21, 2012, 03:58:04 PM »
Gil
I would seriously try the heat gun.  As long as you don't get it hot enough to burn or bubble the epoxy it can only help.  It will even help it flow into the wood better.
Randy C.
Offline Bootlegger
Re: ...rats...
« Reply #5 on: December 21, 2012, 06:54:47 PM »
  Thanks Randy, seeing as how the wife let me have tomorrow off, I think that I'll spend part of the day doin just that.. y1
Gil Causey
AMA# 6964
Offline don Burke
Re: ...rats...
« Reply #6 on: December 21, 2012, 07:39:37 PM »
If all else fails I have added a second coat from a new batch to an uncured area.  This seems to set the underlying.  I do wipe down the coat that hasn't set with acetone before I start.
don Burke AMA 843
Menifee, CA
Offline Bootlegger
Re: ...rats...
« Reply #7 on: January 04, 2013, 11:43:08 AM »
  Don I sent ya' a P/M..thanks Bootlegger
Gil Causey
AMA# 6964
Offline Doug Moon
Re: ...rats...
« Reply #8 on: January 04, 2013, 11:49:02 AM »
I ran into this very thing once a few eyars ago.  I got my plane by a window and let the sun do its job for a day. I kept moving the plane around as the sun would move.  The sun through a window hardened it up.
Doug Moon
AMA 496454
Dougmoon12@yahoo.com
Re: ...rats...
« Reply #9 on: January 04, 2013, 12:10:02 PM »
I would not use a heat gun, use a hair dryer instead if you have one, and keep the plane in a warm place, or where the sun can shine on the epoxy
Re: ...rats...
« Reply #10 on: January 04, 2013, 01:38:08 PM »
Is it polyester finishing resin? If so I found out years ago that it will not set up over anything that has epoxy on it. I had used epoxy around the nose of my Spinks Acromaster to glue it together, and then tried to finish it with polyester finshing resin. After a few days of still being sticky, I removed as much as I could with lacquer thinner, and sanded it all back down. Then I went with thinned epoxy using K&B Superpoxy thinner. That worked much better. I don't remember trying heat, so maybe that will work. Good luck.
Offline Bootlegger
Re: ...rats...
« Reply #11 on: January 04, 2013, 05:08:32 PM »
  Thanks to all y'all, that's Southern for everybody, I heated it up with the hair dryer today and it seem's to be settin up.
  Mr Kraft, this is epoxy finishin resin, not polyester, because I have been told that the polyester will not cure over epoxy also, again thanks for all the advice.
   You guy's sure do help a lot...
Gil Causey
AMA# 6964
Re: ...rats...
« Reply #12 on: January 04, 2013, 10:04:09 PM »
Hey Randy, Ya' have to be careful about suggesting hair dryers to OLD guys...some have absolutely no reason to own a hair dryer... LL~ LL~
Randy C.
Offline Perry Rose
Re: ...rats...
« Reply #13 on: January 05, 2013, 07:06:00 AM »
I put a coat of thinned Great Planes Pro Epoxy finishing resin on a fuselage and put it in a heated room for the day. It must have been over 80 degrees in there and the resin cured nicely in about 8 hours.
Offline Bootlegger
Re: ...rats...
« Reply #14 on: January 05, 2013, 07:14:30 AM »
   Randy Cuberly, EVERY body that knows "The Bootlegger" knows that he isn't "follacally" challenged... y1 y1 y1
Gil Causey
AMA# 6964
Offline gwassenaar
Re: ...rats...
« Reply #15 on: January 05, 2013, 07:23:59 AM »
To Bootlegger. Having read all the previous posts, I miss one hint.
 Next time, use a UV sun tanning unit and direct the rays on your epoxy. I bought a real old fashioned mercury vapour lamp for this purpose and it works miracles. Heat alone will help, but UV really makes epoxy go off.Natural sunlight will  work of course, but not through a glass pane. You would have to put the epoxy in the direct sunlight, outside.
Re: ...rats...
« Reply #16 on: January 05, 2013, 08:13:51 AM »
Randy C.
LOl I know, what ya do is wait till the wife goes shopping...borrow here hair dryer... don't forget to put it back exactly as found 1!.....  if needed wipe off anything that was not on it when you ..er borrowed it..
