  • July 14, 2025, 07:57:15 AM
Author Topic: banana plugs GRRR!  (Read 1757 times)
Offline dave siegler
  • sport flier
    • Circlemasters Flying club
banana plugs GRRR!
« on: August 28, 2017, 09:54:47 AM »
So the banana plugs keep falling you of my power panel, got any ideas. starter cable is stiff.
replace the plugs and the sockets?
I have been tweating the plugs to make them tigher but not too sucessful.
Dave Siegler
NE9N extra class
AMA 720731
Re: banana plugs GRRR!
« Reply #1 on: August 28, 2017, 10:46:35 AM »
You can "expand" the plug.  Put it in a vise and tap the end until it expands.  Most electronic stores have replacements.
Offline bill bischoff
« Reply #2 on: August 28, 2017, 11:43:35 AM »
4mm brushless motor bullet connectors will fit and work better. Or, you could wire a Deans Ultra plug socket right to the battery, and install a matching plug on the starter. I bet it won't accidentally come apart!
Online Paul Smith
« Reply #3 on: August 28, 2017, 12:13:11 PM »
I  noticed that some of the power panels & other banana plugs don't fit so well.  Plugs are under-size.
I have been buying banana plug patch cables from a high end electrical supplier and cutting them in half to make two good-quality plugs.  The cable is factory-sealed to the wire.
Pomona. B-48-2.    pomonaelectronics.com
Offline Peter Nevai
    • C3EL
Offline frank mccune
« Reply #6 on: September 04, 2017, 09:46:53 AM »
    Hi Dave:
    I must concur that a good banana plug is a rare item!  I have tried three different brands and the spring fingers are made of some type of dead soft metal.  I expand them for tight fit, and they are deformed, ruined, the first use.
     Where has all of the quality in goods gone?
        Frank McCune
Online Fredvon4
  • Central Texas
« Reply #7 on: September 04, 2017, 11:57:03 AM »
It went up to $24 and gold plated.... Radio Shack $2.99 sets of 4 were always junk
Fred von Gortler IV
Offline bob whitney
« Reply #8 on: September 04, 2017, 12:02:40 PM »
I have changed almost all of my power panel and electric starter connections to Deans Plugs the one I haven't keeps coming apart at the worst times
rad racer
« Reply #9 on: September 04, 2017, 05:57:02 PM »
     Hello Bob:
     Where does on obtain Deans Plugs?
        Tia,
        Frank McCune
  • sport flier
« Reply #10 on: September 04, 2017, 06:39:56 PM »
it you use deans plugs or bullet connectors, do you have pigtail off the battery?  or something else?
D you have some panel mount solution?
I have a mess of Anderson power poles that I wont use for e- flight.  I may do that.
I need to to that with my glow leads as well.
Dave Siegler
NE9N extra class
AMA 720731
