  • July 13, 2025, 03:49:05 AM
Author Topic: Flap Gap  (Read 1963 times)
Flap Gap
« on: January 20, 2015, 08:56:08 PM »
I forgot to recess the hinges on my Banshee flaps and there's about a 3/16" gap between the wing and flap. Will I really notice a difference at the beginner/intermediate level?
Re: Flap Gap
« Reply #1 on: January 20, 2015, 09:01:24 PM »
  No, since you were going to seal it up with tape anyway.
Online Chris McMillin
Re: Flap Gap
« Reply #2 on: January 20, 2015, 09:06:25 PM »
Only if you try a test and fly it without tape on the hingelines before you tape them.
Chris...
Re: Flap Gap
« Reply #3 on: January 20, 2015, 09:31:38 PM »
I did a search but I'm not clear on how to put the tape on. It just goes on one side? How much slack do you leave in the gap? Doesn't grass stick to the exposed part?
Re: Flap Gap
« Reply #4 on: January 20, 2015, 10:04:38 PM »
http://stunthanger.com/smf/index.php/topic,11355.msg99963.html#msg99963
http://stunthanger.com/smf/index.php/topic,17102.0.html
Yes.  The bottom, where it doesn't show much.
Um -- enough?  If you use scotch tape the amount of slack is pretty non-critical.  Mostly you want to make sure that you can move the surface upward to it's fullest extent.  You can always rip it off and re-do.
You get some grass and dirt, but it's not usually bad.  You can always replace it.
You're welcome.
Offline Balsa Butcher
  • High Desert Flier
Re: Flap Gap
« Reply #5 on: January 20, 2015, 10:18:20 PM »
To reiterate what those posts say regarding the type of tape: Scotch Gloss Finish MultiTask Tape. Comes in a plastic dispenser with red/black tartan patterned label.  Been using it for years.  8)
Pete Cunha
Sacramento CA.
AMA 57499
Re: Flap Gap
« Reply #6 on: January 20, 2015, 11:10:10 PM »
Apparently this tape has been banned in my area because I cant find it anywhere. So Pete has had to install it on my planes when I see him.
Re: Flap Gap
« Reply #7 on: January 20, 2015, 11:31:56 PM »
Offline Larry Fernandez
Re: Flap Gap
« Reply #8 on: January 21, 2015, 10:28:27 AM »
Wow.
That Pete is a swell guy.
Larry, Buttafucco Stunt Team
Re: Flap Gap
« Reply #9 on: January 21, 2015, 03:08:50 PM »
Never thought I'd have to scotch tape my airplane.
Re: Flap Gap
« Reply #10 on: January 21, 2015, 03:21:53 PM »
It makes great hinges for RC foamies, too.
  • High Desert Flier
Re: Flap Gap
« Reply #11 on: January 21, 2015, 08:53:00 PM »
...and great temporary fix for tears/holes in silkspan. On one plane my temporary tape patches have been on for over two flying seasons. :o 8)
Pete Cunha
Sacramento CA.
AMA 57499
Offline Dennis Moritz
Re: Flap Gap
« Reply #12 on: January 22, 2015, 12:17:07 AM »
I used a bandaid on my faux JD Falcon profile. 5 years and counting.
Offline Peter Germann
Re: Flap Gap
« Reply #13 on: January 22, 2015, 04:12:29 AM »
Try this: 3M 850 Polyester Film Tape
Peter Germann
