  • June 20, 2025, 07:11:09 PM
Author Topic: uniflow tanks  (Read 1148 times)
Offline Shawn Kuntz
  • Ringmasters Forever!
uniflow tanks
« on: September 15, 2006, 07:02:03 AM »
I have recently bought two metal uniflow tanks for my profile models.  The tanks come with a rubber hose with a metal plug.  What is the correct way to use these tanks?  Do I plug the overflow tube?
Shawn Kuntz
Bismarck, North Dakota USA
Alan Hahn
Re: uniflow tanks
« Reply #1 on: September 15, 2006, 08:14:20 AM »
The answer is yes --after you fill the tank with it off of course! I assume by "rubber" you mean normal glow fuel tubing.
Offline Tom Perry
Re: uniflow tanks
« Reply #2 on: September 15, 2006, 08:23:10 AM »
The supplied plug will work better than the small molded plastic one some use.  The plastic ones can leak when you use muffler pressure in the uniflo vent.  some put a small ball bearing in the fuel tubing to make the plug.  A tight fitting screw will work also.
Tight lines,
Tom Perry
 Norfolk, Virginia
