Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
June 20, 2025, 06:17:28 AM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Open Forum
(Moderators:
RandySmith
Steve Berry
Testing popular glues.
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Testing popular glues. (Read 1102 times)
Perry Rose
Go vote, it's so easy dead people do it all the time.
2015
Trade Count:
0
Admiral
on:
January 20, 2019, 09:44:12 AM »
Logged
Brett Buck
Trade Count:
0
Admiral
Re: Testing popular glues.
Reply #1 on:
January 20, 2019, 08:26:59 PM »
One of my work buddy's Subaru daily driver is running around with no head gaskets, but JB-Weld (squeezed down to the requisite dimension) and bolts. Need to rebuild it? Too bad, get a new one.
Logged
FLOYD CARTER
24 supporter
Trade Count:
0
Admiral
Reply #2 on:
January 23, 2019, 01:06:27 PM »
JB Weld is often used on model engine mufflers. It holds up well in this application. It is not "forever" because liberal application of heat (from a hot air gun) will loosen JB Weld in case you need to break the bond.
Logged
AMA #796 SAM #188 LSF #020
GERALD WIMMER
25 supporter
Trade Count:
0
Captain
Reply #3 on:
January 23, 2019, 06:25:56 PM »
Hello
I seem to get very mixed results with JB Weld (original formula) on mufflers adding pressure taps or repairing leaks. Sometimes it just goes soft when run and falls apart other times it seems to harden with successive uses and stays good. I used to pre-harden it in a cool oven (212F or 100C) Araldite epoxy for the hour recommended with good results.
Interesting looking at the spec sheet for there general epoxy to see how temperature and age affect strength over time and Methanol degrades it see :
https://www.dawex.cz//userFiles/technicke-listy/huntsman/araldite-2011.pdf
Regards Gerald
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Open Forum
(Moderators:
RandySmith
Steve Berry
