  • July 17, 2025, 05:36:03 AM
Author Topic: PVC Rack  (Read 1973 times)
PVC Rack
« on: November 24, 2016, 11:06:47 AM »
Got too many planes hanging from the rafters so I want to make a standing rack system. Does anyone have plans, advise or pics of a rack made from PVC or some kind of plastic tubing like that?
Re: PVC Rack
« Reply #1 on: November 24, 2016, 10:12:31 PM »
Yeah, somebody posted a picture of theirs not long ago. Try a search. I'm sure it'll help you find that topic.  LL~ Steve
PS: The "search" function here never works for me. Google works, and you can specify what website you want to search....somehow.
Re: PVC Rack
« Reply #2 on: November 24, 2016, 10:21:17 PM »
I did a search and read several threads. Doesn't seem to be a consensus on what size and wall thickness of tubing to use.
Offline Bill Heher
  • Fix-it
Re: PVC Rack
« Reply #3 on: November 24, 2016, 10:35:32 PM »
3/4" inch schedule 40. contractor packs of Tees and 90s.
 from Home Despot /Lowes.
Bill Heher
If it's broke Fix-it
Re: PVC Rack
« Reply #4 on: November 25, 2016, 05:05:49 AM »
I wouldn't. 3/4" isn't rigid enough and will sag over time. Even schedule 40. I'd use 1" minimum.
I built mine out of 2" PVC. Might be a tad overkill, but it's solid as a rock. However, I'm going to redo mine and close up the spacing to get another 2 models on it.
(Click the pick and it turns the right direction)
« Last Edit: November 25, 2016, 05:23:38 AM by Clint Ormosen »
Re: PVC Rack
« Reply #5 on: November 25, 2016, 08:58:08 AM »
What spacing for full size stunters?
Offline mike londke
Re: PVC Rack
« Reply #6 on: November 25, 2016, 10:18:34 AM »
Re: PVC Rack
« Reply #7 on: November 25, 2016, 10:51:45 AM »
Better than PVC  http://stunthanger.com/smf/open-forum/airplane-storage-41605/msg427815/#msg427815
I'm not sure why that's any better than PVC, but still a clever rack system.
Re: PVC Rack
« Reply #8 on: November 25, 2016, 05:34:44 PM »
Mine has to be free standing because, I'll have to move it from time to time.
Re: PVC Rack
« Reply #9 on: November 25, 2016, 09:48:16 PM »
Why does Clint store his airplanes sideways like that?  LL~ Steve
edit: I know it's typical with pictures taken with a cell phone. It's odd, because if you save the picture off the forum into your PC, it won't be sideways anymore. Usually...
