  • June 30, 2025, 09:09:42 PM
Author Topic: 3 bladed prop balancing  (Read 1910 times)
Offline Vincent Judd
« on: May 03, 2018, 05:47:28 AM »
New territory for me.  Can someone please explain the proper way to balance a 3 bladed CF prop?
« Last Edit: May 04, 2018, 05:08:39 AM by Vincent Judd »
Offline peabody
Re: 3 balded prop balancing
« Reply #1 on: May 03, 2018, 06:20:45 AM »
I don't know if you can search Windy's videos on utube, but I know that he did a good one.
And my friend Pete pointed out that step one is to make sure all blades are equal length (two blades as well).
Good luck
« Reply #2 on: May 03, 2018, 08:05:06 AM »
Should have thought to check YouTube first.  There are a ton of videos on there.
Thanks Peabody.
Online Tim Wescott
« Reply #3 on: May 03, 2018, 01:05:58 PM »
Remove material from the blade that's hanging down the most.  Repeat as necessary.  What am I missing?
« Reply #4 on: May 03, 2018, 08:48:52 PM »
I could be wrong, but where a 2 blade needs to be balanced both spanwise and crosswise by grinding/sanding on the side of the hub to get the balance in both axis, the 3+ blades seems to mean that you don't have to do that. The extra blades also seem to run smoother...perhaps because they are better balanced or just easier to balance? Anyway, don't freak out and just be patient!  y1 Steve
« Reply #5 on: May 04, 2018, 05:10:33 AM »
If two blades are hanging down equally try to remove equal amounts from each. Also, in case you didn't know, it doesn't matter how manly you are CF dust will give you lung cancer. Once it goes in it never comes out so protect yourself first time every time.
Motorman 8)
I knew that MM, but thanks for the thoughtful tip.
Re: 3 bladed prop balancing
« Reply #6 on: May 04, 2018, 05:14:12 AM »
When sanding the blades, it's the front, not the back, correct?
Sounds like about as much fun as wrapping leadouts, which I hate.  It's like wrestling with a pig in mud, only the pig likes it.
Offline Frank Imbriaco
« Reply #7 on: May 04, 2018, 04:39:19 PM »
An alternate approach is to quick swipe some medium Ca across the  lighter blade(s).
