  • June 20, 2025, 10:07:22 AM
Author Topic: Parallel  (Read 2172 times)
Online Robert Zambelli
Parallel
« on: August 08, 2024, 05:31:37 PM »
I'm new to lithium batteries and I could use some advice.
I have some 380mAh single cells (3.7 VDC).
Can they be wired up in parallel to yield 760 mAh?
If so, would they be charged separately or in parallel?
I want to use them in my spark ignition planes instead of three AAA alkaline batteries.
Thanks for any help.
Offline Curare
Re: Parallel
« Reply #1 on: August 08, 2024, 05:58:02 PM »
You most certainly can use them in parrallel.
In the past I've just used a Y lead to connect them in parrallel, and charged separately but you can parrallel charge them through the Y lead if you chose to.
Greg Kowalski
AUS 36694
Re: Parallel
« Reply #2 on: August 11, 2024, 05:14:28 PM »
How much current does your ignition system pull?
How much on average, how much with the points closed?
AAA batteries are not good current sources, I suspect that a single cell should deliver plenty of current for a 6-minute flight, and it'll weigh half as much as two cells in parallel.
