  • July 12, 2025, 06:05:29 AM
Author Topic: 2023 Agenda A Build Log  (Read 26245 times)
Offline bill bischoff
Re: 2023 Agenda A Build Log
« Reply #100 on: December 24, 2022, 03:28:33 PM »
You could mold some super light carbon fiber wing tips. The inboard one could be removeable to allow you to use your current adjustable leadout setup. Or, carve the outboard tip out of balsa, then mold the inboard tip from it. Bet'cha can't do it!  >:D
« Reply #101 on: December 24, 2022, 07:54:01 PM »
LOL!
Merry Christmas Wayne.
 I'm serious Crist, it needs them. Would look MUCH better when finished than chopping off the stab/elevator to match.  y1
 Merry Christmas to you too!  H^^
Offline Crist Rigotti
« Reply #102 on: December 24, 2022, 09:01:59 PM »
I knew you were!  I should have said chuckle!
« Reply #103 on: December 24, 2022, 10:36:18 PM »
 No worries, I figured.  :)
Offline Craig Beswick
« Reply #104 on: December 24, 2022, 10:58:06 PM »
Don't people like, "Clipped", wings?
Craig
AUS 87123
"The Ninja"
« Reply #105 on: December 24, 2022, 11:02:08 PM »
Craig
 On a Reno Unlimited yeah, but not in this case.  :)
« Reply #106 on: December 25, 2022, 11:12:52 AM »
I agree with warbird. H^^
« Reply #107 on: December 27, 2022, 03:27:48 PM »
I have the white Monokote on.
Next is the hinging and trim.
« Reply #108 on: December 27, 2022, 03:39:52 PM »
 LL~
That white is so bright it makes the fuselage disappear!  Looking great.  I see you averaged all of the advice on the tips and did nothing.  I am doing a lot of that nowadays. LL~
Offline Pat Johnston
« Reply #109 on: December 27, 2022, 04:36:40 PM »
I love your full body version. This wing with the +P airfoil is a super performer. As fun as your build thread is, I predict the flying is going to be amazing. Thanks for letting us share in your fun.
Pat Johnston
Idaho Skunk Works
« Reply #110 on: December 27, 2022, 05:45:32 PM »
LL~That white is so bright it makes the fuselage disappear!  Looking great.  I see you averaged all of the advice on the tips and did nothing.  I am doing a lot of that nowadays. LL~
Seeing the stab is Monokoted, I can always do something later!
« Reply #111 on: December 27, 2022, 05:48:14 PM »
Pat Johnston
Idaho Skunk Works
Pat, thanks for checking in.  I am looking forward to flying this thing for sure!
« Reply #112 on: January 04, 2023, 10:13:51 PM »
Applied the trim to the wing and stabilizer using Monokote and the "Windex" method.  After it dries out overnight, I go over the trim with my Monokote iron set about 1/2.
After cleaning all surfaces with acetone, I installed the wing and flap horn and flaps.  I had to cut out an extra triangle piece from trailing edge fuselage cutout the wing to slid through.  I then used some 1/8 balsa and put that between each flap root and the fuselage sides.  I then measured from the tail post to the flap tip on the wing and made sure that measurement was equal on both sides.  I then marked the outside of the fuselage sides on the Monokote both top and bottom.
I then removed the wing and cut the Monokote inside of the fuselage 3/8 inch and then cut that edge with a bunch of triangles.  I did this on all 4 edges of the Monokote.  I then sealed down the Monokote real good at the root.
I then slid the wing back into the fuselage along with the flap horn.  The flaps were installed and the 1/8 shims were pinned into place.  Again I measured from the tail post to the flap tip and made sure the measurement was equal and the wing tips were the same distance off the bench.  When I was satisfied all was good, I then tacked the wing in place with medium CA.  I then carefully flipped the whole thing over and tacked the top of the wing in place.
I then fiberglassed the center section both top and bottom with 3/4 ounce glass and my laminating epoxy.  I used an acid brush and forced the epoxy into the fuselage and wing joint.  I then blotted off all the extra epoxy with toilet paper.  It is now curing overnight.
Tomorrow I'll install the push rods and just let the stabilizer float in its slot.  I'll glue it in when I have the fuselage covered in 2/10 carbon fiber and a few coats of clear dope.  The fuselage will be stable and then the stab/wing alignment won't shift through the finishing stage.
« Reply #113 on: January 05, 2023, 10:09:38 PM »
I installed the controls today.  I'm using Tom Morris hardware and carbon fiber push rods.  I used 4-40 hardware and nylon locking nuts.  I used a 4-40 washer between the socket head screw and the ball link.  This will prevent a total loss of control if the ball link pops out of the plastic link.
I also used a 4-40 fender washer on each side of the adjustable elevator horn to keep the ball link from spreading the adjustable part.
I also epoxied in the landing gear mount and the accelerometer mount.
I'm ready to install the top blocks and bottom sheeting.
« Reply #114 on: January 06, 2023, 09:20:33 PM »
The bottom sheeting was applied today.  I wet the parting surfaces with water and glued on the sheeting with my watered down Titebond glue.  Then it was taped in place.  When dry I rounded the fuselage edges and installed the air exit ramp.  I used 1/32 balsa.
I then glued on the top blocks in a similar way.
« Reply #115 on: January 07, 2023, 10:21:30 PM »
Some detail sanding and then I'll be ready for dope!
« Reply #116 on: January 14, 2023, 09:27:28 PM »
I finished the detail sanding.
All dope used is Sig dope and Kleenstrip Lacquer thinner bought at Home Depot.
I applied 3 coats of 75/25 Nitrate/thinner to the bare wood lightly sanding between coats.
I then applied the 2/10 carbon fiber veil with 25/75 Nitrate/thinner.
I then applied 1 coat of 50/50 Nitrate/thinner to the carbon fiber.  I then sanded with 220 grit.
I applied another coat of 50/50 Nitrate/thinner to the carbon fiber.  This was then sanded with 320 grit.  Weight gain from bare wood is 16 grams.
I then glued in the stabilizer using thin and medium CA, and some 15 minute epoxy to fix the elevator horn in place.
I then trimmed and fit the canopy to the fuselage and glued into place using 15 minute epoxy and masking tape to hold it in place.  Look close and you'll see a 1/4 thick "shelf" that I glued to the forward side of the bulkhead to glue the canopy to.  This "shelf" was sanded about 1/32 under size compared to the outside of the fuselage sides so that the canopy would be very close to the fuselage sides.
Next up was the fin.  I marked on the fuselage top where I wanted to slot the top sheeting and cut that out.  I then trimmed the fin to shape.  The bottom portion of the fin is glued to the top of the stabilizer.  Once satisfied, I glued in the fin with some 15 minute epoxy where the fin and stabilizer meet and the aft portion where the fin sits on top of the shaped block.  I used thin CA to glue the fine to the sheeting.
After everything was glued securely, I put the model together to see what it would really look like.
« Reply #117 on: January 16, 2023, 03:20:03 PM »
Once the model was assembled I did the fillets.  I use Aeropoxy because of its strength.  Here is a link that details how I do fillets.
http://stunthanger.com/smf/gettin-all-amp'ed-up!/legacy-40-electric-a-build-log/msg398194/#msg398194
The fillets added 8 grams.  Total weight of the finish is 24 grams.
Next up the filler coats.
« Reply #118 on: January 16, 2023, 06:56:25 PM »
I added the filler coats today.  I used 50/50 Nitrate/thinner and a couple of tablespoons of Zinc Stearate.  I brushed on 2 coats 90 degrees to each other.  When dry I dry sanded with 220 grit.  Weight gained was 3 grams.  Total finish weight is 27 grams.
On to 2 coats of 33/66 Nitrate/thinner to seal the model which they are drying overnight.
« Reply #119 on: January 18, 2023, 10:25:50 PM »
The seal coats are dry and a light sanding was done.
I then brushed on 2 coats of Sig Lite-Coat clear 40/60 dope/thinner.  Then sprayed on 2 more coats of clear 33/67 dope/thinner.  This then dried overnight.
I then wet sanded the model with 600 grit to level the finish.  That was a lot of sanding!  But the finish is level and now ready for the grey blocking coats.
Total weight of the finish so far is 29 grams.
« Reply #120 on: January 20, 2023, 10:32:55 AM »
I sprayed on 1 blocking coat.  I used Sig white with some black added.  40/60 dope/thinner.  After it was dry, I began using the Bondo red glazing putty to fill the dents and imperfections.
The pictures show round one with the putty.
I just finished round 3 and it is now good enough to go with 1 more blocking coat.  Then a light sanding then on to the white.
So far this step has added 10 grams.
« Reply #121 on: January 20, 2023, 10:45:20 AM »
That is looking good.  You have way more patience that I do. D>K
« Reply #122 on: January 20, 2023, 11:54:03 AM »
Thanks Doc!
« Reply #123 on: January 21, 2023, 04:57:38 PM »
After several rounds of glazing and another gray coat I let it dry overnight.  I then wet sanded it flat using 800 grit.
Weight gained was 12 grams.  Total of 41 grams from bare balsa.
Onto the white!
« Reply #124 on: January 21, 2023, 05:00:58 PM »
Teaser!
« Reply #125 on: January 23, 2023, 12:00:05 PM »
The white is done.  I spray the whole fuselage with 2 coats, then where the fuselage will remain white, I sprayed on 3 more coats using 33/67 dope/thinner.
The next day I wet sanded it flat with 800 grit.
Added weight was 25 grams.  Total from bare balsa is now 66 grams.
I'll now spray on a coat or 2 of clear to seal the white.
Offline Clee13
« Reply #126 on: January 23, 2023, 06:30:55 PM »
WOW! Crist that looks amazing. Love the way you blended the canopy into the fuse. Can't wait to see it at the field.
« Reply #127 on: January 23, 2023, 08:25:07 PM »
Thanks!  It'll be a couple of weeks till it's ready for the circle!  See you out there.
« Reply #128 on: January 25, 2023, 05:58:33 PM »
I sprayed on 2 coats of clear 33/67 dope/thinner to seal the white.  The next day I wet sanded it flat again.  I missed weighing it but I figure it was close to 8 grams.  I'll weight it again after the red.
I masked and sprayed on the Fokker Red today.  25/65/10 Dope/thinner/retarder.  Tomorrow I'll wet sand the edges down and flatten the red.  Then shoot the blue.
I'll try and remember to weight it tomorrow for those who are keeping score.
« Reply #129 on: January 26, 2023, 07:33:06 PM »
I wet sanded the red today.  Between the clear seal coats and the red I added 10 grams.  76 grams total so far.
I then shot the blue and frosted the canopy.  The blue is 3 parts Dark Blue and 1 part Miami Blue.  this gives a close match to the Sapphire Blue Monokote that I'm using.
Tomorrow I sand the edges and flatten the blue.  Then it'll be ready for the final clear coats.  I added 4 grams for a total of 80 grams from bare balsa.
My budget now allows me 20 grams for clear coats.
« Reply #130 on: January 28, 2023, 08:06:42 AM »
Hi Crist
I have not been commenting but HAVE been watching - with a touch of envy and jealousy!  The new bird is looking great.  Just meeting your weight schedule would have resulted in a very good outcome.  The fact that you are ahead of your weight targets is fantastic.
Bet it will fly good too!!!
« Reply #131 on: January 28, 2023, 02:03:01 PM »
Thanks Dennis.
« Reply #132 on: January 28, 2023, 08:32:11 PM »
The first couple of clear coats are on. It's been 2 weeks since I started the finish.
« Last Edit: January 28, 2023, 09:38:29 PM by Crist Rigotti »
Offline Dave Rigotti
« Reply #133 on: January 29, 2023, 06:28:29 AM »
Did it orange peel on the wing? LL~
Dave Rigotti
AMA 66859
Chesterland, Ohio
« Reply #134 on: January 29, 2023, 07:40:54 AM »
You may be on to something, the clearcoat on the wing looks a little it needs to buff out???v :o
Offline Dwayne Donnelly
« Reply #135 on: January 29, 2023, 09:01:32 AM »
Hi Crist, do you clear the wings?
« Reply #136 on: January 29, 2023, 11:46:57 AM »
No, they are Monokote.
« Reply #137 on: January 29, 2023, 12:00:21 PM »
You need to hit them with the heat gun, they look wrinkled.  LL~ LL~
« Reply #138 on: January 29, 2023, 02:25:38 PM »
Very funny!
« Reply #139 on: January 29, 2023, 03:39:53 PM »
After sanding the first 3 coats of clear the weight gained was 10 grams.
Today I shot the final 3 coats.  I expect the final 3 coats to weigh 10 grams too.  20 grams for the clear.  100 grams for the finish from bare wood.  Right on target.
I'll let it sit for a few days to rest and harden.  Then on to final assembly.
« Reply #140 on: January 29, 2023, 03:47:05 PM »
Looks beautiful!
Dave Rigotti
AMA 66859
Chesterland, Ohio
« Reply #141 on: January 29, 2023, 04:26:21 PM »
I know, I was just wondering because some do clear monokote, very nice work btw.  :)
« Last Edit: January 29, 2023, 05:53:22 PM by Dwayne Donnelly »
« Reply #142 on: January 29, 2023, 09:26:32 PM »
Monokote and electric equals no extra coatings!
Thank you.
« Reply #143 on: January 31, 2023, 05:03:00 PM »
I assembled the airplane today.  No major issues actually no issues at all.
I'm including a picture of the electronics as I built it up on the bench and all I had to do was to screw in the Arming socket and ESC switch.  Fit real well.
All that's left is to add my AMA number and the name.
As it sits circle ready it weighs 53.3 ounces.
I have to bench trim and program the timer then it'll be ready for first flight.
Offline Mike Griffin
« Reply #144 on: February 08, 2023, 05:53:50 PM »
Hey Crist,
Just got caught up on this build.  All I can say is Beautiful, just beautiful.  You are making much more progress than I am with the Ringmaster 576 build.  Wonderful craftsmanship Crist.
Offline Dennis Nunes
« Reply #145 on: February 08, 2023, 06:37:42 PM »
Well done Crist, well done!  I'll bet it will fly just as good as it looks!
Dennis
« Reply #146 on: February 08, 2023, 09:39:36 PM »
Thanks guys.
Maybe this weekend the weather will be good enough to fly it!
« Reply #147 on: February 13, 2023, 08:16:48 PM »
I flew the Agenda Saturday.  2 1 minute flights to get the lap times close.  On the 2nd flight, I bounced the landing and broke a wheel.  I got carried away and used too light of duty wheels.  Went home and put on some real wheels and added 1/2 ounce of clay to the nose.
I flew it some more today.  2 2 1/2 minute flights to tweak the lap times and see if wings were level in both directions.  The outboard wing was high in both directions.  Added 1/4 ounce.
On the 3rd flight today I flew a complete pattern.  Had an over run!  I reset the timer to 6 minutes and 25 seconds instead of 5 minutes and 25 seconds.  Old age creeping in.
Added another 1/4 ounce tip weight and flew 2 more complete patterns.
It's flying very well and I just have to get some more handle time on it.  It does have a quick corner and comes out of the square corners solid.
I epoxied in 3/4 ounce of nose weight tonight.  With the extra tip weight, real wheels, and nose weight, it now weighs 55 ounces even.
I charged the 2 batteries that had complete flights on them and the first flight in calm wind used 1569ma, and the second flight in winder conditions used 1492ma.  These were using my 6S 2600mah Li-On batteries.  Used about 62%.
Online Matt Colan
« Reply #148 on: February 13, 2023, 08:58:19 PM »
I got to see it fly today.  Crist has a winner on his hands! I looked hard and just couldn’t find it doing anything wrong in the pattern!
« Reply #149 on: February 13, 2023, 09:37:42 PM »
When Matt can't find anything wrong, well there isn't anything.  I had to leave before the first pattern but what I saw impressed me too.  I have not done an ice cream cone airfoil since my 1970 Spitfire.  I may have to give it a try again.  I love the way it accelerates out of corners.
