  • June 20, 2025, 06:56:12 AM
Author Topic: BadAss Motor mounts? - 3D printed  (Read 1264 times)
« on: July 11, 2022, 10:20:44 AM »
Has anyone tried or have any experience with BA’s motor mounts?
« Last Edit: July 11, 2022, 05:10:55 PM by Paul Taylor »
Offline Brent Williams
Re: BadAss Motor mounts?
« Reply #1 on: July 11, 2022, 12:09:48 PM »
The BadAss X-shaped mounts are very nice.
Made from machined aluminum, not cast aluminum.
The slotted mounting holes make alignment much more forgiving and versatile.
« Last Edit: July 11, 2022, 10:23:50 PM by Brent Williams »
Offline John Rist
« Reply #2 on: July 11, 2022, 04:26:03 PM »
Are you talking about the X shaped motor mount that comes with the BA motor?
« Reply #3 on: July 11, 2022, 05:10:10 PM »
No sorry guys. The 3D printed ones.
They would mount on a firewall.
https://innov8tivedesigns.com/3d-printed-motor-mount-for-35mm-motors-25mm-length.html
Offline John Rist
Re: BadAss Motor mounts? - 3D printed
« Reply #4 on: July 11, 2022, 08:16:31 PM »
Ok they are designed to move a rear mounted motor forward. COOL!  #^  Most everything I have is front mounted.  Looks like if you are using a rear mounted motor and want to change to shorter motor of the same series this will make it possible and easy.
« Reply #5 on: July 11, 2022, 08:26:50 PM »
You can get them in different sizes depending on what is needed.
It is made with PETG that is tough stuff.
Anyone see a down side to using one?
Online Perry Rose
« Reply #6 on: July 12, 2022, 07:46:13 AM »
I have one on my Mo' Best with a large Bad Ass motor. It slides into the normal space that the wood bearers would be. Takes glue well and is strong.
« Reply #7 on: July 12, 2022, 10:05:25 AM »
Thanks Perry!
Can you please post a photo on how you mounted it?
