  • July 10, 2025, 09:17:51 PM
Author Topic: blank  (Read 1597 times)
blank
« on: August 12, 2018, 09:12:40 PM »
blank
« Last Edit: September 26, 2021, 10:50:19 PM by Motorman »
Re: 1x1 Leading Edge
« Reply #1 on: August 12, 2018, 09:41:18 PM »
Looking for old style 1x1 shaped balsa leading edge for a vintage combat plane I'm building. Similar to the old S1 Ringmaster leading edge only bigger. LHS use to have them but they closed up.
  Google is your friend:
http://www.specializedbalsa.com/products/lead_trail_aileron.php
Offline Tom Luciano
« Reply #2 on: August 13, 2018, 03:56:18 AM »
Motorman,
  Another option is Sig. I have bought multiple sizes from them. I always buy a few to ensure I get at least one straight one.
Tom
Actually, I just check Sig. they're only showing 1x 3/4 not 1x1.
AMA 13001
Offline Skip Chernoff
« Reply #3 on: August 13, 2018, 05:41:25 AM »
I have some of that shaped leading edge material. You may have it. I'll see how straight it is.
Offline Tom Luciano
« Reply #4 on: August 13, 2018, 07:03:34 AM »
MM,
  I checked my recently built Hatchet. I did use the Sig 3/4x1. Pictured is the profile. I also checked my kit built VooDoo and that also has a 3/4x1 leading edge. I also noticed the 1x1 looked a bit pointy as well. As we have learned over the years blunt is better.
FYI- that's 3/4" deep x 1" height
Hope this helps and hope you make the vintage combat day!
best,
Tom
« Last Edit: August 13, 2018, 07:21:50 AM by Tom Luciano »
AMA 13001
« Reply #5 on: August 13, 2018, 11:38:36 AM »
Some of those leading edge shapes are almost triangles the one I'm looking for is a bullet shape.
Have at it:
   www.google.com
Offline Tony Drago
« Reply #6 on: August 13, 2018, 12:09:04 PM »
I believe the Midwest leading edges are what you are looking for.
Offline Dane Martin
  • heli pilot BHOR
« Reply #7 on: August 13, 2018, 12:11:01 PM »
This is probably the correct vendor for the LE.
But! I've found it best to do a parabolic cut and make a LE shaper on the table saw when you can't find exactly what you're after.
« Reply #8 on: August 13, 2018, 12:21:51 PM »
Why not take a 1x1 piece of balsa and shape it to what you want?  It will likely be straighter than the shaped piece you purchase and you can be more selective as to the density/strength you want.
Offline Brent Williams
« Reply #9 on: August 13, 2018, 12:45:55 PM »
I would just redraw the ribs and go with a built up or a molded leading edge.
https://stunthanger.com/smf/open-forum/ringmaster-balsa-leading-edge-wing-material-where/
Offline Gordon Van Tighem
« Reply #10 on: August 13, 2018, 02:11:38 PM »
I have a few available....
Gord VT
MAAC 3738L, Life Member
AMA C3738L
