  • August 04, 2025, 03:55:19 AM
Author Topic: 1948 Tuckette  (Read 1999 times)
Offline Bill Morell
1948 Tuckette
« on: July 06, 2021, 05:53:26 PM »
I am building one these that is a copy of the Enterprise kit. The wing tips are just sheet balsa with no bracing. If I change the tips but retain the outward shape is that acceptable? I would like to put ribs on the tips not only for strength but also to be more pleasing to the eye.
Bill Morell
Vietnam 72-73
Offline Elwyn Aud
    • Inferalandings Photo Page
Re: 1948 Tuckette
« Reply #1 on: July 06, 2021, 07:23:54 PM »
I am curious as to what one looks like.
Re: 1948 Tuckette
« Reply #2 on: July 06, 2021, 07:57:54 PM »
As long as the addition to the tips can't be seen, you are good to go.  But, I have seen adjustable lead outs that no body protested as well as out board wing weight boxes. D>K
Offline James Lee
Re: 1948 Tuckette
« Reply #3 on: July 06, 2021, 08:07:59 PM »
As long as the outer surface stays the same, the construction does not matter.   Many of the old designs needed some better internal engineering....    ~^
Jim
Re: 1948 Tuckette
« Reply #4 on: July 06, 2021, 11:29:45 PM »
Adjustable leadouts and outboard wing weight boxes should never be protested or even suggest that they could be protested.  From the PAMPA Rules for Classic Stunt:
"...Adjustable tip weights, leadouts and removable landing gear ... are allowable."
« Last Edit: July 07, 2021, 07:37:20 AM by Trostle »
Re: 1948 Tuckette
« Reply #5 on: July 07, 2021, 01:14:19 PM »
Thanks Keith,  I think I'm developing dementia. H^^
Re: 1948 Tuckette
« Reply #6 on: July 07, 2021, 07:10:28 PM »
Color me confused. I would have expected a 1948 design to be built to the OTS rules and not the Classic rules.  D>K Steve
Re: 1948 Tuckette
« Reply #7 on: July 07, 2021, 07:24:15 PM »
OK.
PAMPA rules for OTS:
Among the listed "Allowable Modifications":
"Adjustable Leadouts"
"Adjustable Tip Weight"
There are some provisions about the landing gear for OTS, but none prevent the use of a removable landing gear system.
Online John Park
  • Agricola
Re: 1948 Tuckette
« Reply #8 on: July 08, 2021, 02:48:48 AM »
So am I.  Any resemblance to the Hot Rock?
Offline Joe Bowman
Re: 1948 Tuckette
« Reply #9 on: July 08, 2021, 09:35:04 AM »
I have a picture of the Tuckette but unsuccessful in posting it.    Says I am timed out, try to resubmit. pdf file is only 149kb.  ???????
Offline Joe Bowman
Re: 1948 Tuckette
« Reply #10 on: July 08, 2021, 01:00:34 PM »
Let's try this.
Re: 1948 Tuckette
« Reply #11 on: July 08, 2021, 02:02:23 PM »
Interesting airplane.  Shows how things have evolved.  This thing is only a bit larger than a good 1/2 A stunt ship, yet the add shows it can be for a .65.
Built light, an .09 or a 15 might make a good combination for OTS.
Offline Tom Luciano
Re: 1948 Tuckette
« Reply #12 on: July 08, 2021, 02:26:47 PM »
looks like a drone diesel up front
AMA 13001
Offline Bill Morell
Re: 1948 Tuckette
« Reply #13 on: July 09, 2021, 12:01:53 AM »
The engine in the photo is a 1948 Torpedo. 24 glow
 The plans show this as well I just acquired a .29 for mine which is also on the plans. I wanted the correct engine for this project.
Bill Morell
Vietnam 72-73
Online John Park
  • Agricola
Re: 1948 Tuckette
« Reply #14 on: July 09, 2021, 03:58:53 AM »
Nice-looking little thing - NO resemblance to the Hot Rock.  Should go beautifully with a 2.5cc diesel.
Offline Bob Hudak
Re: 1948 Tuckette
« Reply #15 on: July 09, 2021, 11:50:06 AM »
Nice looking? My tastes must be different. It makes a Flite Streak look sexy.
« Last Edit: July 09, 2021, 12:10:55 PM by Bob Hudak »
350838
Online John Park
  • Agricola
Re: 1948 Tuckette
« Reply #16 on: July 10, 2021, 05:18:43 AM »
Funny, I always thought a Super Combat Streak had a certain je ne sais quoi about it.  Anyway, compare the Tuckette with the average 1948 C/L design, and it stands up pretty well - at least as neat as the SNAFU Magician (which, by the way, flies very well if you build it light and don't over-power it - a .19 is just about right).
