  • July 17, 2025, 11:29:41 PM
Author Topic: 10/25 finish !  (Read 2331 times)
10/25 finish !
« on: October 27, 2017, 04:35:06 PM »
Looks Like 10 points from 25 ft away.
My goal was to lose weight and mostly in the tail. ( that's what she said)
I think I have done the best I could for what it is. I stripped it down and replaced a few panels. I airbrushed acrylic paint on and did not mask anything. I did that so I would not pull up any paint. And have that airbrushed look. 2k over entire plane. It is what it is. A tool. 52oz. PA 40UL.
Re: 10/25 finish !
« Reply #1 on: October 27, 2017, 04:37:18 PM »
And wanted to thank everyone for the input on this makeover project.
Offline Dane Martin
  • heli pilot BHOR
Re: 10/25 finish !
« Reply #2 on: October 27, 2017, 04:42:38 PM »
I like it. Sounds like a good weight
Offline James Holford
Re: 10/25 finish !
« Reply #3 on: October 27, 2017, 06:38:13 PM »
Id fly it in public :)
Jamie Holford
Baton Rouge Bi-Liners
Lafayette, La
AMA #1126767
Re: 10/25 finish !
« Reply #4 on: October 27, 2017, 06:47:11 PM »
I too like the looks of the affect it has.    How you got nice straight lines with an air brush is amazing.
Re: 10/25 finish !
« Reply #5 on: October 27, 2017, 06:52:33 PM »
So you used acylic paint.. then clear coated? Hmmm that opens up options on my end and I have quite a bit of acrylic from my plastic modeling....
Jamie Holford
Lafayette, La
AMA #1126767
Re: 10/25 finish !
« Reply #6 on: October 27, 2017, 09:33:04 PM »
Thanks Doc. It's not hard.
Re: 10/25 finish !
« Reply #7 on: October 27, 2017, 09:35:28 PM »
Yep. Tamiya paints.
This plane was painted with it as well on the top.
Re: 10/25 finish !
« Reply #8 on: October 28, 2017, 05:27:23 AM »
Yep. Tamiya paints.
Have plenty of tamiya paints!! Reckon I will habe to go follow up on your build thread on covering and such. I knew I should habe asked you bout all this last weekend.
Jamie Holford
Lafayette, La
AMA #1126767
Re: 10/25 finish !
« Reply #9 on: October 28, 2017, 10:00:21 AM »
Jimmy Lynch is Da Man. He has been teaching me how to build and his finishing  techniques.
I'm a slow learner.😜
And as he always tells me ... it's just balsa wood and paper.
Re: 10/25 finish !
« Reply #10 on: October 28, 2017, 11:19:59 AM »
Tamiya paints.
I've been using them for years and have mentioned this in my many Threads, plenty of times.
Glad to see the information in my Threads are being put to good use.  ;D
CB
Re: 10/25 finish !
« Reply #11 on: October 28, 2017, 12:06:40 PM »
What is this "2K" ?  I have used auto clear coat (2-part), but never heard of 2K.
Offline Allan Perret
  • Proverbs
Re: 10/25 finish !
« Reply #12 on: October 30, 2017, 07:26:31 AM »
2K is just another name / label for 2-part.
Allan Perret
AMA 302406
Slidell, Louisiana
Re: 10/25 finish !
« Reply #13 on: October 30, 2017, 09:21:17 PM »
    2K is what Spray Max calls their two part urethane paints. I have never seen two part paints referred to this way any place else. It just got picked up as part of the forum vernacular.
