  • June 24, 2025, 03:29:36 AM
Author Topic: ..10-32 acorn nut  (Read 1232 times)
Offline Bootlegger
..10-32 acorn nut
« on: December 31, 2014, 04:28:54 PM »
  First of all Happy and Prosprues New Year to all aboard.
  I am looking for a few 10-32 acorn nuts for a couple of my engnes, any help will be appreciated..
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Jim Carter
Re: ..10-32 acorn nut
« Reply #1 on: December 31, 2014, 04:35:49 PM »
Howdy!  I found these listed:  http://www.amazon.com/b?node=16409871  Hope it helps!
« Reply #2 on: December 31, 2014, 05:44:51 PM »
I found some acorn nuts at my local Ace Hardware store.   Had to replace the bolt in my Brodak muffler.  Acorn nut on one end of an all threaded rod and regular nylon insert nut on the other end.  Then cut off excess.
Offline bill bischoff
« Reply #3 on: December 31, 2014, 09:37:03 PM »
Tru-Turn has several choices.
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #4 on: January 01, 2015, 07:08:14 AM »
If it's a spinner nut you are wanting, I personally like the OS better than the others I have tried.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXCC37
Never mind, was thinking the smaller OS engines were also 10-32, not sure how 5mm converts and doubt it will fit.
Offline Bootlegger
« Reply #5 on: January 04, 2015, 05:45:08 PM »
  Thanks fellow's  I found 'em..  Again thanks for the advice/help
Gil Causey
AMA# 6964
