  • June 19, 2025, 03:38:56 PM
Author Topic: incidence meter..  (Read 1311 times)
Offline Bootlegger
incidence meter..
« on: December 18, 2009, 10:18:27 AM »
  Mornin' Fellow's  I have an older incindence meter  that isn't  the laser type, what type do you use and do you like it?
 I do want to be as accurate as I can with setting this stuff..
  I also am using a line level on the crank shaft of the engine, what do you use on your engine??
                       Thanks a lot,             #^
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline david beazley
Re: incidence meter..
« Reply #1 on: December 18, 2009, 02:03:17 PM »
I use a couple of old Robart incidence gages.  I looked at the laser ones but was not impressed.  I use 1 on each wing half to make sure there are no twists.  It makes it easier than trying to move one from one wing half to the other.
AMA # 2817
Offline Don Curry AMA 267060
« Reply #2 on: December 18, 2009, 02:49:25 PM »
I prefer the old
robart meter. I have two laser meters and the Robart is much more accurate. Plus the batteries are not dead when I need it most.
Don
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #3 on: December 18, 2009, 03:03:03 PM »
I fell for the laser hype also, durn thing isn't worth using. Bought a Robart, then about a year ago bought a Great Planes digital. The old Robart can be read just as accurate as the digital and it's really hard to beat. Only thing better is having two.
Offline Bootlegger
« Reply #4 on: December 19, 2009, 07:09:44 AM »
     Thanks a lot Guy's that is what I was lookin' for, and Merry CHRISTmas to everyone... y1
Gil Causey
AMA# 6964
