  • July 05, 2025, 10:09:13 PM
Author Topic: Building a new Super 70s plane  (Read 67666 times)
Re: Building a new Super 70s plane
« Reply #50 on: November 11, 2019, 09:36:10 PM »
Still haven't figured out how to set up the arming plug and start button
 That's easy, the arming plug screws into the cylinder head and the start button is on your starter. Glad I could help.  VD~
« Reply #51 on: November 12, 2019, 12:37:37 AM »
You've got about 3 times the space. It's more figuring out where to put the battery plugin. I'm using Dean's bulkhead mounts.
You may be right, I kept the pipe tunnel in the design so I probably have more room at the bottom.  I used the same concept on a converted ARF Nobler and got both the timer and the arming plug into the cowling leaving the entire tank compartment for the battery with the esc between the mounts under the battery.  Still the most I could fit was a stubby 4s.  Turnegy makes a rather thin 4s and 5s in there "Nano" line that would probably fit in around the 3000 - 3300 size.  Not as light as the Thunderpower but they perform well.
I have gone to placing the esc into the wing area behind the battery to keep it from forcing cooling vents in the top and to move some weight closer to the CG.  I was tired of having to add tail weight.  Hopefully in what is left of my usable lifetime we will have a battery that doesn't weigh so much and is smaller.
It is hard with the "Classics"/N30's to find room for a decent size battery.
I absolutely love the plane so far, even if you aren't going to paint it as a Weasel!
« Last Edit: November 12, 2019, 06:20:22 AM by Ken Culbertson »
« Reply #52 on: November 13, 2019, 10:55:41 PM »
Thanks for the nice comments. Glad I'm causing Bob some harsh flashbacks. It's a fun plane to build overall. Lot of challenges but hey, that's why we do this stuff.
« Reply #53 on: November 14, 2019, 08:12:42 PM »
 Fun to watch people build these designs that can do them justice too.  y1
« Reply #54 on: November 17, 2019, 04:51:50 PM »
Still working on pieces. Carving and fitting the air intakes and drop tanks. Bob had an evil turn of mind when he designed this dude. Sill messing with shapes. Started on the flaps, too. Decided to finish much of the front of the air intakes before mounting them. Later it will be too big a pain to get in there. Still fitting electronics. Another joy.
« Reply #55 on: November 24, 2019, 05:12:11 PM »
Well Bob, the tanks have been the most challenging for me. I hogged the intakes all out and put a backstop to imitate an inset. I finished the intake part up to ready to paint as I didn't think I could get in there to sand after they were on. Got one drop tank done. Sheesh, that was a ton of work.   ;D
« Reply #56 on: November 25, 2019, 07:37:51 AM »
......a great choice for the slightly larger models that we were all starting to build to accept the more powerful and slightly heavier .40 size engines that were beginning to become available....
LL~
« Reply #57 on: November 25, 2019, 04:53:11 PM »
Wayne, the pylon is glued to the wing but the tank bolts on. I was pretty happy. The tank and pylon weighed in at about 15 grams.
Bob, hope mine lasts awhile. I'm planning to use basically the same setup I used in the ill fated Mirage. It seemed to have plenty of power. 2826-10 930kv motor, 60 amp esc, Hubin timer and a 4 cell, 2800mAh battery.
« Reply #58 on: November 30, 2019, 05:52:27 PM »
Bit more progress. Both drop tanks done, the cowl is roughly fitted, main gear bent but still working on the gear doors and about half done with a battery hold down system. Just about ready to complete the flaps and then it will be on to final sanding and finish.
« Reply #59 on: November 30, 2019, 10:24:01 PM »
 Looks cool. I bet it's gonna be some fun blending those intakes into the wing.
« Reply #60 on: December 01, 2019, 08:48:12 PM »
Man, it's been a ride.  Parts of this plane are insanely difficult, but it's should be cool. I'm having a ball building it. Bob is a genius. Clearly.
 ;D
« Reply #61 on: December 01, 2019, 11:57:46 PM »
This is bringing back memories of all the insane things we built in the 60's and 70's.   This one was one of my favorites. I wish I had built it.  I did build one along the lines of the F-14 with the huge intakes.  Didn't last long, faulty clevis but it flew remarkably well.  I was surprised that all that junk under the wing and intakes had no noticeable impact on how well it flew.  That 2nd picture has "Fly Me" written all over it.  Anybody who worked on these magnificent planes will never forget the sound of the AB makes when they take off with a full load.  "Thud" and the ground shakes, which ironically is not where it got it's nickname!  Paint it up as a 105F. (I never give up)
« Reply #62 on: December 05, 2019, 04:31:12 PM »
I like the "F" but no camo.
« Reply #63 on: December 05, 2019, 07:04:25 PM »
 Man this one is tough. I keep searching every so often for '104 schemes but it's either camo or semi-boring bare aluminum with very minimal squadron coloring. Apparently there were no "colorful" groups using them. All I do know is the world doesn't really need another model done in a Thunderbird scheme.
« Reply #64 on: December 06, 2019, 01:20:40 PM »
Say hey Randy, drive'em nuts and go for a  Blue Angles theme.  LL~ LL~ LL~ LL~ LL~ LL~
Have you ever encountered a pissed off Weasel? ~^
Just for grins I went back and looked at 105f/g paint schemes and except for some of the most God awful sharks noses and some naked women, that has to be the most boring plane in history.  I did find one that was painted yellow on a video, then it got hit by a missile - a target drone.  Don't think that I would paint one up to look like a target drone. I tried to find some pictures of the prototypes since they usually paint them up pretty but found zero.
Good Luck Randy
« Reply #65 on: December 08, 2019, 12:39:24 PM »
I found the paint scheme I'm going to use, but it doesn't vary much from Bob's original.  Two tone gray, some blue and red and a touch of yellow.
« Reply #66 on: December 08, 2019, 08:19:51 PM »
 Cool, anxious to see this one.  y1
« Reply #67 on: December 09, 2019, 05:01:50 PM »
The vents look better in person.
Offline Bob Hudak
« Reply #68 on: December 09, 2019, 08:03:34 PM »
Ditch the silver and use white instead, it's not full scale. Built an electric F105 in 2013. The retracts have been trouble free. Yes she still flies!
350838
« Reply #69 on: December 16, 2019, 03:07:27 PM »
So, one flap done. All that's left is the outboard flap and fairings.
« Reply #70 on: December 23, 2019, 09:21:56 AM »
So, it's built. Doing the wiring at the moment then will move on to final sanding and begin the finish. I will say, this thing has extremely free controls. Been awhile since I built a plane that just the weight of the flaps will pull them down.
« Last Edit: December 23, 2019, 01:11:23 PM by Randy Powell »
« Reply #71 on: December 23, 2019, 12:39:29 PM »
Throw in a picture or two of the "electronics bay" (sounds better than "tank compartment") when you get it finished.  I am curious how you laid it out.  Are you venting through the spinner gap?  All of my electrics have a huge front intake and a whole bunch of rear vents.  You don't have any way to do that.
Can't wait to see it finished.
ken
« Reply #72 on: December 23, 2019, 01:08:50 PM »
Well, unfortunately, I had to cut a bunch of vents. Shame, that.
« Reply #73 on: December 23, 2019, 07:05:52 PM »
 You know, if it had a "tank compartment"...  VD~
 Seriously though, looks really cool Randy, time to get out the blue stuff!
« Reply #74 on: December 24, 2019, 11:34:20 AM »
Well, I found out the motor I was going to use is on back order.  May not get to fly at VSC after all. We'll see. Little late to retrofit now.
« Reply #75 on: December 24, 2019, 09:22:13 PM »
 Ouch, that's a bummer. Didn't you have a motor to work with during the build though? IDK, maybe with electric there's a million of them all with the same dimensions?
« Reply #76 on: December 25, 2019, 12:16:20 AM »
Cobra 2826/12 or the BadAss 2826-690 or 2826-1030 should all fit.  I elaborated on your other thread but I may have been thinking a front mount.  From the early pix it appears you used a rear mount.  Even with a rear mount, those three motors should fit.  There is a 1.5mm difference in overall length with the BadAss.
« Reply #77 on: December 26, 2019, 10:14:03 AM »
Thanks for the offer, guys. I found one. I wanted to have two separate setups. If the thing ends up being tail heavy (a possibility), I wanted a heavier drive train to use instead of adding nose weight.
So Setup Number 1:
Cobra 2826/10 930kv motor, 60amp ECS, Hubin Timer and 4s 2800 mAh battery.
or
Cobra 2826/12 760kv motor, same ESC and timer, 5s 2800 mAh battery.
When I built it, I had the 2826/12. Either setup would work but I prefer the lighter one if possible.
« Reply #78 on: December 26, 2019, 11:24:56 AM »
So Setup Number 1:
or
I run your "or" setup on my classic Nobler.  I have to use a 4s to shoehorn it in.  The 2800 will barely finish the pattern.  It should be fine on a 5s.
I would be curious to know what your battery usage will be on the 2826/10.  It should be less than the /12.  Reason I ask is that I am converting another ship that has plenty of room.  I was going to get a new motor.  If what you are doing works, I can move the /12 to the other ship and get a /10 for the Nobler.  Or I could just get another 2820/12 but it won't take a 5s and, who knows how small batteries will be next year!
You going to fly it unfinished?  I would.
« Reply #79 on: December 26, 2019, 03:00:55 PM »
I used the 2826/10 with 11x5 three blade carbon prop and a 4s battery in my Mirage. 620sq inches and weighed, well, a lot. 68oz ready to fly. left about 15-16% in battery. Plenty of power.
« Reply #80 on: December 28, 2019, 08:26:44 PM »
Well. it's built. Took about 6 hours to fit all the stuff in the nose. Lots of modifications to get stuff to fit. But all up ready to fly with 5s battery (I'll probably be using a 4s), prop, spinner, wheels, ESC, timer and arming system came up to 54oz. Heavier than I wanted but with 4s ~3oz less. Balance is pretty far forward so should work with 4s and finish.
And that's not the prop I'm using.
« Reply #81 on: December 28, 2019, 09:38:26 PM »
 Way cool Randy. What's the backwards scoopy looking thing on the left side of the nose?
« Reply #82 on: December 30, 2019, 09:28:42 AM »
Had to have some place to put the start button.
« Reply #83 on: December 30, 2019, 10:08:17 PM »
 Does anyone make a simple remote start setup for these things?
« Reply #84 on: December 31, 2019, 11:47:58 AM »
Probably.
« Reply #85 on: January 04, 2020, 06:35:57 PM »
OK, so it's covered. Man, this is going to need a lot of sanding. GM on wings, 00 everywhere else.
« Reply #86 on: January 17, 2020, 09:59:54 PM »
 Must still be sanding?  ;D
« Reply #87 on: January 23, 2020, 02:41:48 PM »
And sanding and sanding and sanding.......  Om-Madai-Padi-Ummmmm....
Doing 600 wet right now. Then it will be color time. Tomorrow, I hope.
Had an interruption. My wife took a dive off her horse and severely dislocated her hand and fractured her wrist. The last week I've been nursing her after surgery and such. Threw my schedule off a bit.  ;D
« Reply #88 on: January 31, 2020, 01:27:59 PM »
Paint this weekend. WooHoo!!
« Reply #89 on: February 02, 2020, 05:10:03 PM »
So, some of it's painted.
« Reply #90 on: February 02, 2020, 09:06:55 PM »
OK, I pulled tape. Next is Olive Drab then some Black and some Red and some stripes on the rudder and then......
« Reply #91 on: February 05, 2020, 03:29:02 PM »
Thanks, Bob. Nice picture.  ;D
« Reply #92 on: February 08, 2020, 08:45:56 PM »
About half done with trim. Should be able to finish trim plus graphics tomorrow. Then a ton of inklines. Ugh.
« Reply #93 on: February 08, 2020, 08:53:37 PM »
This is the vague guideline.
Offline John Leidle
« Reply #94 on: February 09, 2020, 09:51:29 AM »
    Looks pretty nice from over on the East side Randy.
« Reply #95 on: February 09, 2020, 07:57:31 PM »
 I was wondering about the green, but I get it now.  :)
« Reply #96 on: February 09, 2020, 09:41:06 PM »
Anti glair.  They painted them with clear lacquer in Germany and they shined.  Randy was smart to pick the 36th.  Most military planes are painted flat.
« Reply #97 on: February 10, 2020, 02:30:47 PM »
Seemed the thing.
« Reply #98 on: February 10, 2020, 02:40:10 PM »
Still some black. Then graphics, ink and clear.
« Reply #99 on: February 10, 2020, 09:17:04 PM »
Anti glair.
 Yep, I knew that, most often anti-glare panels were done in black though. I just thought the green seemed an odd choice for the "Thud", until I saw the reference Randy is using. There are very few F-105 schemes to pick from that have much for color, Randy found a good one here.
