  • July 08, 2025, 02:42:11 AM
Author Topic: Trim Question  (Read 855 times)
Offline John Sunderland
Trim Question
« on: September 28, 2010, 11:33:16 PM »
The retro-fit im in the process of rebuilding had positive incidence in the stab and one dgree out and down thrust in the engine. If I run a reverse motor and a pusher prop...what can I expect trim wise. Anyone else ever had this come up? H^^
Offline TDM
Re: Trim Question
« Reply #1 on: September 29, 2010, 05:42:41 AM »
Did you look at this post?
http://stunthanger.com/smf/index.php?topic=17518.0
You may what to cosult David's article regarding the incidence on the stab he starten this trend and you my have to go the opposite direction.
Re: Trim Question
« Reply #2 on: September 30, 2010, 07:50:38 AM »
 H^^ Thanks Dorin...yes I read that thread and guess I forgot Jose had asked this before. Still...only Paul offered any real inflight insight. I will set the engine 0/0 and go from there. The posi in the stab may cause a problem...but we can always ad up trim...sounds weird having never needed to do so before...just have to see I guess!
Offline jose modesto
Re: Trim Question
« Reply #3 on: September 30, 2010, 09:09:43 AM »
John one of the great features of a firewall mounted motor is that by putting small washer under the engines mounting bolts you can move engine in any direction. I have a take apart emodel that was converted from IC this model had 1to2+ incidence in stab motor required one washer under mounting bolts to give motor up thrust with reverse pitch. this could also be a not perfectly aligned fire wall.
Jose Modesto
Offline Dean Pappas
Re: Trim Question
« Reply #4 on: September 30, 2010, 08:53:56 PM »
Welcome to pioneer-dom, John!
We are all learning anew at this stage.
Dean
Dean Pappas
Re: Trim Question
« Reply #5 on: October 03, 2010, 04:27:06 PM »
Thanks fellas for the responses. I guess I am kind of hoping to show up next year ready to compete. I dont mind trimming and actually like it...problem is for us mid country folk is we barely get any flying weather and then must show up ready for the Nats like a week or two later. Trying to get a leg up. This summer was another wash but did get out to some local meets. Forget the competition, I just feel better when I am hanging with my friends and its great to see those who are moving up..do it!
