  • June 15, 2025, 10:47:43 AM
Author Topic: Prather Pitch Gauge (Reversed)  (Read 1250 times)
Offline Darkstar1
« on: December 12, 2009, 10:01:53 AM »
Here's a easier way to do the pitch gauge. I've taken off the plate scanned it, reversed the image
Sprayed 3M on the paper stuck it to the backside, trimmed excess paper then fitted gauge plate
in the other direction. Warning:The pivot screw is a 5-40 tap. Did not know that when I had my first one  <=
The other screws are 4-40. Drill & tap the 4-40s in a new spot cause you will need to countersink them.
If everything is lined up right the pointer should line up perfect as shown in the pic below. If not U can always
take it off print another one & try again. Here's the scan if lined up it should fit perfect. And don't forget to
cover the paper with clear tape afterwards.
Enjoy  H^^
Later,
Evolve or get left behind!
Online Dennis Toth
Re: Prather Pitch Gauge (Reversed)
« Reply #1 on: December 12, 2009, 02:23:46 PM »
Darrell,
Thanks for the post, its good to have the full reverse pitch gauge.
Best,              DennisT
« Reply #2 on: December 13, 2009, 01:03:36 AM »
That is pretty clever, but I would just pitch the prop while looking in a mirror.  Wait, you'd need to look at the prop in the mirror, but the pitch gauge not in the mirror, or conversely.
Offline John Witt
« Reply #3 on: December 13, 2009, 04:23:05 PM »
Howard's getting cabin fever.   LL~
John W
John Witt
AMA 19892
Edmonds, WA
"Houston, Tranquillity Base here. The Eagle has landed."
Offline John Witt
« Reply #4 on: December 13, 2009, 04:24:39 PM »
It would be really great if someone who has Prather guage would measure it and post a plan. I'd like to make one.
John W
John Witt
AMA 19892
Edmonds, WA
Offline Allan Perret
  • Proverbs
« Reply #5 on: December 14, 2009, 08:01:38 AM »
John W
Do a search for "Hooptee" and you find a great plan for pitch guage.
Allan Perret
AMA 302406
Slidell, Louisiana
Offline John Cralley
« Reply #6 on: December 14, 2009, 09:32:34 AM »
John Cralley
AMA 52183
Central Illinois
Offline John Witt
« Reply #7 on: December 14, 2009, 05:55:02 PM »
Cool, John.  Many thanks. I've wanted one of these since I saw one in Howard's van.  #^
John W
John Witt
AMA 19892
Edmonds, WA
Offline johnbyrne
« Reply #8 on: December 19, 2009, 09:15:27 AM »
Hey Ty,
John here, we flew at El Dorado together.  A quick hi before going into the main post :)
Anyway, I'm the one who re-did the Hootee in the link posted above.  Hope someone has found a use for it.  I still use the proto from time to time and it works perfect.  I did draw the Pranther but I don't think I ever posted it.  I could reverse it pretty easy and make a pdf if anyone is interested.
By the way, I posted the Hooteetoo on this site as well.   Search my posts and one could find.
AMA 759448
Offline johnbyrne
« Reply #9 on: December 19, 2009, 09:17:51 AM »
Here is the stunt hanger link with pics ;)
http://stunthanger.com/smf/index.php?topic=11210.0
AMA 759448
