Here are a few pics for your viewing pleasure. First is an original (the original perhaps). The next few show the beta unit.
I ran out of 1/8" play (grrrr) so I used Plexiglass for the front. It was thicker than 1/8" (3/16" I think) so I couldn't use the standard 3/4" wide backer. What I did was simply measure back from the front such that the middle of slot A was at 1" and went from there.
I left the base square. The plans show it like the original but obviously it can be made square. The base is 3/4" "sandy" ply from Home Depot and the 1/4" pieces are hard wood from again Home Depot. Found these in the molding section by the wood dowels. I added the cross brace as an after thought and it does help keep the prop down but isn't really needed.
Back light the scale to see the gap between the prop and scale. The last picture shows an APC 10x4 in slot D. Pretty close. I have an 11x5 APC that measures about 4.5 all the way down. The first 2 slots (A and B) are pretty much useless due to the prop shape and the tip on an APC is almost impossible too. The middle is pretty easy though.
The prop mount is made like the original as circled on the plans. I turned some hard balsa on my dremel. Drilled a hole, inserted 4-40 blind nut (can be seen in the picture), screwed bolt through and chucked it. While spinning I sanded it to shape. SUPER easy. The Cone can be threaded down onto the prop given the blind nut is still there so this works out pretty good. The pointer is made of 1/16" ply and I think this may work better than the 1/8" on the plans. It doesn't seem to need the bevel where it touches the prop. I mounted the pointer with a wood screw. The counter sunk type head removes all slop from the pointer hole as you tighten it down yet still moves nice. It also stays where you put it. Seems perfect but time will tell.
