  • August 02, 2025, 04:43:48 AM
Author Topic: Another goodie from Saito, Choke 56/62  (Read 5757 times)
Offline Bob Reeves
    • Somethin'Xtra Inc.
« on: September 15, 2009, 04:47:04 AM »
Was ordering a couple items from Horizon and ran across this little goodie. I can see a couple uses for it. First it could be easily set up to allow choking of a cowled in engine which is it's intended purpose. Second, with a little linkage engineering it could be used for an adjustable intake choke even on the Control Line intake. The price is sure right, I ordered a couple just to play with, think it's pretty cool.
http://www.horizonhobby.com/Products/Default.aspx?ProdId=SAI5092
Offline Bryan Higgins
Re: Another goodie from Saito, Choke 56/62
« Reply #1 on: October 07, 2009, 03:23:17 PM »
Did you see the new F-1 Filter $9.97  Real nice
Bryan R higgins Jr.
Arvada,Colorado
AMA#885188
Offline Bob Reeves
« Reply #2 on: October 07, 2009, 06:01:04 PM »
Ya saw the filter.. real nice for a flight box, I like the weight and size of Master Airscrew plastic for airplanes. I seal them with a heat shrink cover.
