  • August 01, 2025, 09:01:44 PM
Author Topic: What Saito to buy???  (Read 5768 times)
Offline Bryan Higgins
« on: October 07, 2009, 03:18:47 PM »
Hello Pilots
I am building a Fokker D7 Scale Model 56" WS and 6-7 pounds in weight.
What Saito 4 stroke do you think i should buy for it ? D>K
Bryan
Bryan R higgins Jr.
Arvada,Colorado
AMA#885188
Offline Bob Reeves
    • Somethin'Xtra Inc.
Re: What Saito to buy???
« Reply #1 on: October 07, 2009, 05:57:06 PM »
What do you expect it to do? A 56 or 62 will fly it, 2 ounces less than a 72 but if you need it to do more than a loop I would go with a 72.
« Reply #2 on: October 07, 2009, 06:40:55 PM »
Bob
It is just a scale model to fly in circles with I probably will try to learn the basics
of scale flight - take off , climb , touch & go and landing.
Model should come out to 7 lbs.  I was looking at the Saito .82 at Horizon it has
a good price but i heard it shakes or vibrates alot.  Is that true?
Chuck S. told me to go with a .91 .  Just want to get a few more peoples opinions.
I also heard that .91 are a great running Saito...    Bryan
Bryan R higgins Jr.
Arvada,Colorado
AMA#885188
Offline Robert Zambelli
« Reply #3 on: October 08, 2009, 12:51:54 PM »
Bryan - I have flown/owned every SAITO from the .30 to the .91 and they're all fine engines.
The  .82 did not have any excessive vibration. For stunt the power to weight ratio was a bit low but nevertheless, it still worked well on the 80 ounce Red Baron, pulling it through the entire stunt pattern.
I would suggest the .82 or .91.
« Reply #4 on: October 08, 2009, 04:44:42 PM »
7 lb. weight-no brainer Saito 91. Maybe just one of the best all round Saito's made. Smoother than the 82 and more powerful.
