Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
August 01, 2025, 08:21:50 PM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Engine basics
Four strokes only
(Moderator:
RandySmith
Gummed up.
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Gummed up. (Read 2347 times)
Dan Labine
2013 Supporter
Trade Count:
0
Commander
Gummed up.
on:
January 31, 2012, 06:47:16 AM »
I just purchased a OS 26 4 stroke which was run a few times. When I tried to turn it over it resisted my efforts. I do not want to force it over in case I break something. Any suggestions on freeing it up??
The engine looks brand new..
Dan
Logged
Dan
MAAC 14300
Andrew Tinsley
Trade Count:
0
Admiral
Re: Gummed up.
Reply #1 on:
January 31, 2012, 07:22:39 AM »
Use a hot air gun and GENTLY heat it up, it should move after that, don't burn your fingers! If your wife is out then comandeer the oven and let it warm up that way, but do NOT use a high heat.
Andrew.
Logged
BMFA Number 64862
Bob Reeves
2016 supporter
Trade Count:
0
Admiral
Re: Gummed up.
Reply #2 on:
January 31, 2012, 07:40:17 AM »
What Andrew said.. I would pull the valve cover just to make sure it hasn't rusted. I bought a Saito 30 off eBay several years ago that looked great on the outside but when I pulled the valve covers it was a rusted mess. Thankfully the seller took it back, am sure it was the result of being ran on cheap RC fuel and no after run oil.
Logged
Dan Labine
2013 Supporter
Trade Count:
0
Commander
Re: Gummed up.
Reply #3 on:
February 01, 2012, 12:08:08 PM »
Thanks Guys.
The heat did the trick. Valves were clean. Turns over nicely now.
Dan
Logged
Dan
MAAC 14300
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Engine basics
Four strokes only
(Moderator:
RandySmith
Gummed up.
