  • July 05, 2025, 11:04:43 AM
Author Topic: schulze ESC  (Read 12567 times)
Offline Grahame Goodson
  • GG
schulze ESC
« on: May 06, 2021, 04:41:18 PM »
Hello from “down under”...🇦🇺🦘
Just wondering if any one has any info on setting up the Schulze  61K F2  B  controller. Mine came with virtually zero info for control line use even they are supposed to be so designated for that purpose.
Thanks in advance,
Grahame G
Offline pmackenzie
  • Pat MacKenzie
Re: schulze ESC
« Reply #1 on: May 06, 2021, 10:31:15 PM »
Does it use DIP switches for programming?
I have the manual for the 18.46 F2B, I can scan and post it tomorrow.(Assuming I can find it :) )
For the 18.46, the things that make it suitable for F2B are the brake in governor mode, and the operating RPM range and fineness of the adjustment.
The regular controllers don't have brake in heli governor mode, and the RPM range they cover is much larger so the adjustments end up being fairly coarse.
For governed mode they just sort of work, no muss no fuss. I don't know if they will work as effectively with an active system however.
Pat MacKenzie
MAAC 8177
Offline pmackenzie
  • Pat MacKenzie
Re: schulze ESC
« Reply #2 on: May 07, 2021, 02:07:07 PM »
Here is a scan of the "hints" page for the 18.46 F2B controller.
MAAC 8177
Offline Dwayne Donnelly
Re: schulze ESC
« Reply #3 on: May 07, 2021, 04:06:46 PM »
If it helps these are the switch settings I'm using on my 18.46 F2B with a Pat MacKenzie/Kim Doherty timer
1-0ff
2-on
3-on
4-on
5-off
6-off
Hope this helps. :)
  • GG
Re: schulze ESC
« Reply #4 on: May 08, 2021, 07:10:52 AM »
Thanks to both Pat and Dwayne....
Yes, the controller does have the dip switches for setting. The 46 seems to have been a specific esc for C/L , but I am not sure about  the 61.
The information  provided is much appreciated, and a great starting point for me. I will put it to the test, and get back....🤞🇦🇺
Thanks again,
GG
Re: schulze ESC
« Reply #5 on: May 08, 2021, 08:01:44 AM »
Thanks again,
GG
Another thing, the 46 does not have a built in BEC, I don't know about the 61
  • GG
Re: schulze ESC
« Reply #6 on: May 11, 2021, 06:56:33 AM »
Thanks to you both...again❗️
The F2 B hints will be most helpful. It seems that the manuals I have cover a multitude of controllers including the 46 and 61, but the offer was much appreciated.
As were the DIL switch settings. Both of my 61 controllers, (no BEC’s) came with quite different default settings....🤔but I will use your recommendations.
Best wishes,
GG
« Last Edit: August 13, 2021, 11:39:28 PM by Grahame Goodson »
Offline Kim Doherty
Re: schulze ESC
« Reply #7 on: May 14, 2021, 08:52:27 AM »
GG
Grahame
Both the 46 F2B and 61 F2B are faster than a regular r/c esc. They were optimized for our purpose. They are not to be used for r/c. They are not opto coupled among other refinements. They are both exclusively for C/L use only.
Kim
  • GG
Re: schulze ESC
« Reply #8 on: May 16, 2021, 12:19:15 AM »
Thanks Kim,
I was a little confused, as one controller had “F2B”  penned on  the esc label with a marker, the other one had no such marking. The DIL switches were set differently,  otherwise both units appear identical.
Appreciate your input.
GG
