  • June 14, 2025, 06:32:00 PM
Author Topic: gain on KR timer?  (Read 8952 times)
Offline Charles Hofacker
gain on KR timer?
« on: September 03, 2020, 06:17:34 PM »
What is the "gain" function on a KR timer? and if you use a KR timer what is your gain setting?
Offline pmackenzie
  • Pat MacKenzie
Re: gain on KR timer?
« Reply #1 on: September 04, 2020, 10:44:46 AM »
Gain adds boost in the corners,as explained on the Keith's web site:
http://www.keithrenecle.co.za/Electric%20CL.htm#Govtimerinfo
I can't help with setting though,I have not used a KR timer (yet)  :)
MAAC 8177
Offline Don Jenkins
« Reply #2 on: September 27, 2020, 05:56:32 AM »
The default gain setting is "1" which is little to no gain.  I have mine set on one plane at "4" and another plane at "5".  It's easy to change between flights, but the higher gain setting yields more RPM when going through maneuvers that draw additional current from the motor, so the planes' speed is constant and the lines stay tight all the time, or at least that's what you hope for!!
Don
Offline Matt Piatkowski
« Reply #3 on: January 01, 2021, 10:42:08 AM »
Hello,
The gain parameter in KR timer is a "double edge sword".
Increasing it's numerical value will add RPM when the system wants to draw more current, for example when the model is entering the Wing-over.
Unfortunately, this RPM increase is not reasonably stable for higher gain parameter values while the model is climbing.
There exists RPM fluctuations that are clearly audible.
This has to do with the dynamic properties of the PID systems.
The highest gain I consider acceptable is 4.
Matt
Offline Ray Nyce
« Reply #4 on: March 07, 2021, 04:04:30 PM »
I use KR timers on all my planes and for about 10 years now
.  combat and stunt.
I look at the gain as allowing me to fly slower in level flight which is very helpful.
The gain then powers you up to enough power for the maneuvers.
My standard setting is 4.
When I set the gain too high, my system starts to oscillate- i.e. it speeds up, then slows down in about 5 second cycles.
4 is just right for my planes and has not been a problem.
Set to 5, I get into the oscillating scenario half the time.
