  • July 14, 2025, 10:10:28 PM
Author Topic: Phoenix Edge Lite 75A  (Read 11767 times)
Offline Peter Germann
« on: February 22, 2014, 04:00:22 AM »
Fireshark
67 oz   680 sq.in
AXI 2826/12
APC 13 x 5.5 EP, 9'030 RPM set on FM-9 (9'210 loggged), 5.3 sec/lap on 64 ft x 0.015,  5.30 run time set.
Hubin FM-9 (Phoenix New Gov. Mode)
TP G8 Pro Force 2700 mAh 5S, 1'900 mAh recharge
Anti spark plug on battery
Castle Creations Phoenix Edge lite 75 A Firmw. V 4.19 (Beta)  & Castle Link V3.56.20
Vehicle Type: Control Line
Throttle Type: Governor Mode
Governor Mode Setting: Governor High
Governor Gain: High (35)
Initial Spool Up Rate: High
Head Speed Change Rate: High
Brake Strength: 100%
Brake Delay: 0.5 sec
Brake Ramp: Medium (59)
Cutoff Voltage: 15.0 V
Auto-Lipo Volts/Cell: Inactive  (Due to anti-spark plug on battery)
Battery Pack Voltage: 18.500
Current Limiting: Very Sensitive
Voltage Cutoff Type: Soft Cutoff (allows emergency ldg. in case of battery going dead)
Current Cutoff Type: Hard Cutoff (prop strike)
Motor Start Power: Medium (59)
Motor Timing: Custom (4)
Direction: Reverse
PWM Rate: 8 Khz
Gearing Info: No Gearing/Direct Drive
KV of Motor: 760
Magnetic Poles in Motor: 14
Power-On Beep: Enabled
BEC Voltage: 5.0 V
Link Live Enable: Disabled
Auxiliary Wire Mode: Disabled
Logging; (5 samples/second)
Batt. Voltage, Batt. Current, Contr.Temp. Contr. Input Throttle, RPM, BEC
Automatic Data Reset: Always, on power on
Peter Germann
Offline MarcusCordeiro
Re: Phoenix Edge Lite 75A
« Reply #1 on: February 23, 2014, 03:49:33 AM »
Nice ship!!!!
Thanks for sharing.
Marcus
Live to fly, fly to live
Aces High!
Here comes Marcus, man..."
Offline Carl Cisneros
« Reply #2 on: September 21, 2014, 10:36:17 AM »
Peter;
thanks for your listing.
that is what Iwill use for my set up programming for my Castle Phoenix Ice 75 ( I do not have a Lite).
Folks like yo umake life a whole lot easier for everyone else.
Keep up the great work.   H^^
Carl
Carl R Cisneros, Dist IV
Control Line RB
