Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
August 02, 2025, 03:31:53 PM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Electric Stunt
ESC Settings
Jeti Spin programming
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Jeti Spin programming (Read 10496 times)
Igor Burger
Trade Count:
0
Admiral
on:
November 19, 2014, 09:33:29 AM »
Tania converted my text describing parameters for Jeti Spin ESCs as I use them to home page. I think it will be good to post the link also here.
http://www.maxbee.net/articles/spinprog.htm
Logged
José Almeida
Trade Count:
0
Ensign
Re: Jeti Spin programming
Reply #1 on:
November 20, 2014, 06:02:51 AM »
Thanks Igor.
For those less familiar with the electrics, is an excellent base to starting!
This is the same for all Jeti Spin ESC or particulary for Jeti Spin 66?
Logged
Igor Burger
Trade Count:
0
Admiral
Reply #2 on:
November 20, 2014, 07:36:05 AM »
Yes, it is valid for all Spins and Spins opto. I use the same settings for indoors with Spin 11 (with different RPM). But not valid for Spint PRO and Spin PRO OPTO.
Logged
Dennis Toth
2020 supporter
Trade Count:
0
Admiral
Reply #3 on:
November 25, 2014, 11:13:13 AM »
GreatPrimer. Maybe someone can pin it to the top so it doesn't get lost.
Reading through it seems the Jeti Spin has an active brake for stopping the prop rotation on shut down similar to the Castle ESP's, correct?
What is the max rpm that it can operate at in governor mode?
Best, DennisT
Logged
Igor Burger
Trade Count:
0
Admiral
Reply #4 on:
November 25, 2014, 02:12:05 PM »
Yes Spin has brake, it is the only way for FAI F2B.
I do not think that governor has any RPM limitations, but ESC itself has I think 200 000 rpm for 2 pole motor, means up to 30 000 on 14 pole motor. But I am not sure.
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Electric Stunt
ESC Settings
