  • June 22, 2025, 11:54:39 PM
Author Topic: Phoenix Edge 75 Lite Programming Questions  (Read 7151 times)
Offline Vincent Judd
« on: July 30, 2013, 07:09:20 PM »
As everyone probably knows by now, CC no longer offers the Ice Lite ESC's.  Their latest and greatest is now called the Edge.  I just got one to go along with my E Flite 32 that I installed in my SV-11.
Here are my settings, please let me know if anything looks out of place:
Vehicle Type :Control line
Throttle Type:  Governor mode
Governor: High
Governor Gain:  Medium (25)
Initial Spool up Rate High 8
Head Speed Change Rate  High 8
Battery Pack Voltage  18.5
No gearing/Direct Drive
kV of motor 770
Magnetic Poles in motor (14)
Desired Head Speeds  (Set with my Hubin FM-9)  Will reprogram once I see what my lap times are
Brake Strength   100% (Hard)
Brake delay  0.6
Brake ramp  Medium
Cutoff voltage  (Auto Lipo)
Auto Lipo volts per cell (3.2)
Voltage cut off/type:  Hard cutoff
Current limiting (Very sensitive 75A)
Current Cut off type:  Hard cutoff
Motor start power:  Medium (59)
Motor timing:  Custom 4
Direction:  Reverse
PWM Rate 8
Power on Beep:  Enabled
BEC Voltage:  5.0V
Link Live Enable:  Disabled
Auxiliary Wire Mode:  Disabled
Data Logging:  2/sec  Battery voltage, currrent, controller temp/ throttle, motor RPM
Take care and thanks.
Vince
« Last Edit: July 31, 2013, 07:27:11 PM by Vince Judd »
Offline jim welch
Re: Phoenix Edge 75 Lite Programming Questions
« Reply #1 on: July 30, 2013, 08:08:52 PM »
Vince see the other thread above this one....jim
AMA 89335
« Reply #2 on: July 31, 2013, 07:26:10 PM »
Jim, thanks for the reminder.  I read and reread Norm's cookbook last year when I tried to program my Ice Lite 50 and found it extremely helpful.  I should have taken the time to read it again this year, but I was in a hurry.  Many of my initial questions would have been answered.   Still have some questions about various settings, but I now have many of them figured out thanks to the cookbook and the information contained in it.
