Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
---->Stunt News click here<----
June 20, 2025, 02:39:57 AM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
Evolution 60 ??
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Evolution 60 ?? (Read 2034 times)
Bill Little
2017
Trade Count:
0
Admiral
Second in COMMAND
Evolution 60 ??
on:
August 08, 2015, 12:16:20 PM »
OK, Gentlemen, I tried the search function but no luck.
How much fuel is needed with the stock set up for the pattern? I have a possible candidate for this engine and the fuel tank size it limited. Will be using 5% nitro the majority of the time.
Also, what % of oil is the best choice? All synthetic?
Thanks!
Logged
Big Bear
AMA 95351 (got one of my old numbers back!
Walter Hicks
Guest
Trade Count:
0
Re: Evolution 60 ??
Reply #1 on:
August 08, 2015, 01:39:31 PM »
This engine was provided with specific instructions as to which fuel to use. Some people thought they knew better and used the wrong fuel
and said the engine did not run well. Use what is recommended by manufacture all synthetic 17-18 per cent oil fuel such as Cool
Power See the many posts on this Pete Cuna ,Bill Hummel , Mike Massey have all commented on this I have seen Mikes planes fly with
this motor excellent stunt run.
Logged
Bill Hummel
25 supporter
Trade Count:
0
Captain
Re: Evolution 60 ??
Reply #2 on:
August 08, 2015, 04:13:08 PM »
With the smaller venturi, and the RECOMMENDED fuel, we were using about 5.75 ounces per flight. Nice
traditional soft 4/2/4 run, excellent starting character hot or cold. Virtually no vibration as well! Sorry they
are no longer available...
Logged
ama 72090
Matt Piatkowski
Trade Count:
0
Captain
Re: Evolution 60 ??
Reply #3 on:
August 09, 2015, 05:17:17 AM »
I do have this engine (EVOE0600) with C/L venturi setup.
Very good power/weight ratio and the same mounting holes pattern like Jett 60
Will try both it in my modified Score.
Logged
Balsa Butcher
24 supporter
Trade Count:
0
Admiral
High Desert Flier
Re: Evolution 60 ??
Reply #4 on:
August 09, 2015, 06:44:40 PM »
I use Powermaster, 10% R/C fuel. 5.5 ounce tank and it takes about 5 1/4 ounces for the pattern. I'm sure full synthetic would work but regular R/C blend works fine and is easier to find. Prop is an RSM 12x5.5 (currently unavailable of course) but a Zoar or any other good quality 12x5 or 12x6 should work as well.
Logged
Pete Cunha
Sacramento CA.
AMA 57499
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
Evolution 60 ??
