  • June 20, 2025, 04:52:21 PM
Author Topic: Head gasket for OS 32F  (Read 1259 times)
Offline Akihiro Danjo
« on: August 08, 2013, 06:27:03 AM »
I am looking for head shims for OS 32F. OS stock# 22914000 is not sold anymore.
Does anyone know a head shim that is suitable for OS 32F?
Aki
Online Bill Hummel
Re: Head gasket for OS 32F
« Reply #1 on: August 09, 2013, 09:55:16 AM »
Aki, it's been quite a while, but I seem to recall we used Fox 35 head shims in the 32F.
ama 72090
Dwayne
« Reply #2 on: August 09, 2013, 10:52:24 AM »
I used gaskets from a OS 35 AX
« Reply #3 on: August 09, 2013, 10:21:29 PM »
Thank you very much for the info, BH san and DD san.
I will order 35AX gasket because it is much cheaper and easier to get here in Japan than Fox.
I had not checked AX because current engines tend to have thicker wall cylinder and larger head.
Thanks again, Aki
Dwayne
« Reply #4 on: August 10, 2013, 07:15:36 AM »
Thanks again, Aki
Now that I think about it the AX is a bit wider but it does work no problems.
