  • June 29, 2025, 04:31:28 PM
Author Topic: What will remove old castor oil from an engine?  (Read 1604 times)
Offline frank mccune
« on: April 07, 2015, 06:43:18 PM »
      Hi All:
      I need to clean some engines that have old castor oil 4 decades, on and in them.  What will remove this varnish?  How about paint stripper, oven cleaner or?????
        Tia,
        Frank McCune
Offline Bud Morrison
Online RandySmith
Re: What will remove old castor oil from an engine?
« Reply #2 on: April 07, 2015, 07:08:25 PM »
      Hi All:
        Tia,
        Frank McCune
Berrymans  Carb cleaner in the gallon dip bucket, or antifreeze in a crock pot will do the trick
Offline Gerald Arana
« Reply #3 on: April 07, 2015, 07:49:08 PM »
Whatever you do, do not use anything with ammonia in it. It will turn the engine black.........don't ask me how I know.  ::)
Crock pot is best, IMHO. (Not so humble.)  LL~ LL~ LL~
Jerry
« Reply #4 on: April 07, 2015, 10:32:48 PM »
      Hi All:
    No caustic chemicals!  Crock pot with plain old green Prestone anti-freeze is the gold standard. It's as close to a miracle cure as I have seen in my 40+years.
Offline Gene O'Keefe
« Reply #5 on: April 08, 2015, 08:08:22 AM »
Sounds simple but remember to remove any plastic parts & o-rings & gaskets before the crock pot - the antifreeze will destroy them.
Gene O'Keefe
AMA 28386
