I have a 25Vf , Randy pipe and a MAC's header,I seem to remember reading that you leave the header the full length and
cut the pipe? As the header can handle the heat better is this correct still.
Also chasing a source of silicon tubing for the pipe it would need to 15mm ID, (16mm or 5/8" is not a tight fit.)
